2025 OEM TPMS part#?
T-Wrecks
Mark
Roberts, WI
25 XLT FX4
I'm swapping OEM wheels from my 2019 to my 2025, figure the TPMS should be replaced after 6 years. What's the part#, and frequency? Is OEM the only way to go?
I bought some off amazon or ebay, not any particular brand though.
The 25 have a different frequency from the 24 and older,.from what i read
purdyd
california
Mine were 433 MHz
added a spare on matching rims
tire shop handled the tpms which I assume was a third party unit as they programmed the frequency.
T-Wrecks
T-Wrecks
Mark
Roberts, WI
25 XLT FX4
Mine were 433 MHz
All the OEM Ford parts I can find online only list the 315 MHz? But Tire Rack says 433 MHz.
purdyd
california
I believe it is this tpms117?
https://www.ford.com/product/tire-pressure-monitoring-system-tpms-sensor-p4000187546
from this thread
https://www.ranger6g.com/forum/thre...ls-possibly-only-the-later-build-dates.23098/
again the tire store had to read my tire frequency to determine which frequency to use
some of the third party tpms units can be programmed to either frequency.
and I think early production 2025 might be 315 Mhz
fortunately I am not an expert on this as my new tpms works and I can rotate five tires and the spare when it Is moved into the rotation,gets picked up after awhile without having to do anything
good luck!
Chuck2001
Montreal, Canada
25 RR, 24 Golf R
I'm looking for a definitive answer. Soon to switch to winter tires.
I'm in Canada and thinking about installing Michelin X-ice or Continental VikingContact 8 in 265/70R17 size on stock 17x8.5" Ranger Raptor wheels.
And putting the KO3s Method wheels in spring.
I just ran my stock ones(they Mud & Snow rated) on my Lariat and I was fine last winter but you in Quebec and need winter tire as it's the law.
I ran into some issues trying to use my 24’ sensors in my 25’.
I think it was a late model 25 change. Ford‘s own parts website showed the same part number for both 24s and 25s.
That proved not to be the case.
Least not for mine that was built in August 25.
I can only assume 25 models must have started out using the same sensors and there must have been a running change later in the year.
docshelby
Macan Turbo
Optometrist
from this thread
good luck!
docshelby
Macan Turbo
Optometrist
Well I'm about to find out going to add the 5th wheel Tuesday. I will report back.
