2025 Ranger Lariat Leveling Kit Help.
JBAJ
JON
Charleston, IL
I have a 2025 Ford Ranger lariat with the performance LED lights, I want to install a full 3 1/2 inch lift kit and noticed that if I do this, I’m gonna screw up a bunch of the sensors. So my question is if I go with a 2 1/2 inch leveling kit Will this be OK?
a lot of people have 2.5 on their trucks here, i believe. there actually should be tons of threads on choices to compare if you are kind of bored and want to do a quick search here
GLW
Missouri
This may be of help.
ntbruncie
Nick
Phoenix Arizona
With just a 2-2.5” level you shouldn’t need to reprogram any of the sensors as far as the headlights go I’m not sure with the performance leds I just have the standard leds in my xlt.
JBAJ
JON
Charleston, IL
Ended up with a 2.5 inch lift, bigger tires, 2 inch wheel spacers and no issue at all with any of the sensors. Also added a new exhaust system, Rhino liner, tint, and mud flaps. All in all with the tires the truck sits 3.5 inches taller and
Ford Ranger 2025 Ranger Lariat Leveling Kit Help. IMG_0068
Ford Ranger 2025 Ranger Lariat Leveling Kit Help. IMG_0066
Ford Ranger 2025 Ranger Lariat Leveling Kit Help. IMG_0069
Ford Ranger 2025 Ranger Lariat Leveling Kit Help. IMG_0067
JBAJ
JON
Charleston, IL
I’ll post some better pictures after a wash and in better lighting.
Looks good
burbansk
Bruce
Mio MI.
2015 Ford F150 FX4, 2024 Ford Ranger Lariat FX4
That looks GREAT. Who made your lift kit and were there any difficulties with the install?
NevadaBob
Nevada
2024 Ranger Lariat
Looks great. What size tires did you go with? Also, is there a drawback to using spacers vs going to a different offset wheel? I like the look with the wider stance on factory wheels. And the price.
RangerPA
York County, PA
2025 Ranger XLT FX4
2.5" leveing lift with 275/70R17 and no issues at all.
Ford Ranger 2025 Ranger Lariat Leveling Kit Help. IMG_5597
Ford Ranger 2025 Ranger Lariat Leveling Kit Help. IMG_5593
RangerRod
2024 Ranger Lariat
Human Resources Director
RangerRod
2024 Ranger Lariat
Like the setup. Looks good and more aggressive but not over the top. I like the Lariat wheels, what size tire did you use? Brand? Did you go with the 2-inch spacers on all 4 wheels or just the two front? The 4 tires stick out just enough to give the truck that wider aggressive look. Would like to do the same to my 2024 Lariat. Thanks
Any problems getting the alignment back to spec with a 2.5" lift? Or do we need new UCAs?
