2025 XLT with a A.R.E. CX Classic truck cap installed
bigb
Tucson
2025 Ranger 2.7
I ordered my A.R.E today, MX series with mid rise, 2 Windoors, tilting and sliding rear window, Yakima roof rails and Bedrug liner. Should take about 8 weeks for delivery. Below are some computer generated images. BTW RealTruck owns A.R.E. now.
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed ARE1
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed ARE2
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed AER3bed rug
My ARE topper made it to my dealer today.
Scheduled for installation week from Thursday before they could get me in.
‘I did run by and check it out, looks like everything is correct.
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed IMG_4574
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed IMG_4575
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed IMG_4576
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed IMG_4577
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
The Ford Body Builder Guide shows what wire to tap on the BCM for the 3rd brake for accessories. I tapped that, and ran a wire out through the firewall access behind the bcm as per the fbbg. It also showed a high beam trigger, a marker light trigger, and a ignition run/start trigger. I then got some single run 3 conductor wire 14G and ran it to the back of the truck, following the factory harness, and opening and tucking in troughs to hide/protect it. the ground is connected to the ground point on the fender support with my arb dual battery kit/truck battery, and hot wire is on thr "low draw" side of the battery terminals per the fbbg, and the brake wire goes from the bcm wire to the back, where it is powering the cap 3rd brake, and my Diode Dynamics ssc1r's brake function under the bumper. The marker and reverse and ground are through their trailer harness. once I removed the brake side of the c1r's, I stopped getting the trailer kight malfunction errors.
the marker light trigger is used to turn on my grill lights, tell my diode dynamics dswitch to turn on night mode, dims the switch panel(and once I get my diode dynamics light bars over the winter/spring, I will enable the sensor wire the marker is hooked up to to turn on the back lighting/accent lighting on the bars) the run/start wire is used to tell my dswitch to turn on and off automatically when I start the truck or shut the truck off fully(start/stop doesn't effect the ignition wire under the bcm) and can still manually turn on and off the dswitch with the truck shut off and key removed.
the highbeam trigger is hooked up to one of the dswitch sensor wires, and is set to automatically turn on what channels I select in the app. so right now it automatically turns on my 10" lightbar in the lower grill.
I realize this is my cap thread, and went a little off topic, but figgured easy to answer majority of the questions I might get in this comment. lol
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20250922_091611_Adobe Acrobat
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20250922_091623_Adobe Acrobat
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20250922_091559_Adobe Acrobat
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20250922_091636_Adobe Acrobat
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250822_150423
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250830_230445
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250829_194702
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250830_230434
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250822_092217
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
Looks nice. Do you mind listing the vertical height measurement from the bed to the cap door opening, and inside from the bed to the interior ceiling of cap, please? I'd like to estimate a total cargo capacity.
I can when I get free in a bit if I remember. but basically measure from the top of your bed rail, to the top of the cab. this picture was when I had to get rescue my father in laws chickens from the mandatory evacuation from a forest fire earlier the summer that was way to close for comfort. was less then 700meters from my womens grandmother, and 1100 meters from the fadder inlaw
I have to make up my mind between a cab height and a mid-rise. No roof rack planned. I wish someone with a mid rise would post a pic.
I do miss the high rise on my old ranger, but for the plans I want to do, I went with the low rise.
If your not getting a platform etc, I'd get the mid or high, you can still get roof rack/rails for them, but my setup I want to do is a roof rack on the truck, and then either 2 baskets, or a platform and basket on the rack on truck, and cap. and didnt want them up too high.
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250812_004146
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250811_235911
bigb
Tucson
2025 Ranger 2.7
Does the body building manual show anywhere to connect for a 12 volt outlet in the bed? I know I can tap the trailer tow wire but I've heard rumors there might be a plug somewhere on the harness to plug in the 12 volt socket harness. I'd like to have at least a #12 AWG to support a 5 amp fridge draw with voltage drop considerations.
It's been my experience with running my lights on my headache rack off the trailer tow wire harness, tends to set off the auto trail detection and shuts off several of the safety features.
Essentially using that trailer harness triggers the truck to think there is a trailer hooked up.
I dove pretty deep into trying to find some way to turn off the auto trailer detection to no avail.
The dealer tried their Ford computers as well as Forscan aftermarket programmers nothing seems to be able to turn off auto trailer detection.
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
Nope. but the 12v power is already there under the bed. This is the plug the bed power point panel plugs into, ypu can see its 6 wires in one side of the plug, and only 4 going out. 2 are the +/- for the 12v, and the other 4 are for the 110v plug. you can get the pins and put them in the connector and run your own 12v socket. or if perfer the oem look and dont mind paying for new, order a 24 ranger power panel.. or get one from junkyard.
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250622_143142
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
thats why above I included the fbbg with taping the 3rd brake light circuit at the bcm. as per ford. I did this with the c1r's brake signal. I had to cut the left/right brake/turn wires off of diode Dynamics harness. capped the one end. and tied both left/right c1r wires into the 1 brake wire from the bcm. this got rig of my trailer light error. Now if you want backrack STT's you need to have sepperate lights for brake, and sepperate for turn, and go at the tail light wires.
the putco lightblade only available on ford accessories, uses tail light passthrough connectors to get the STT signals from the tail lights and not the trailer plug.
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250729_193731
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20250729_194019
Yea my ARE topper dealer pretty much described to me what you posted pics of earlier wiring it directly into the BCM under the hood.
Least that is what they explained to me when I was asking about how they were going to wire in the high mount stop light found on these toppers. Which sounds like that was going to prevent the trailer issues I have been fighting with the lights in my headache rack.
The headache rack is more than a brake light though, it is also turn signals and reverse lights.
Which I have it programmed into a default or active trailer as being only 2ft long and that lets me get my blind side monitors back on, but still don't have rear park sensors anymore on that truck.
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
If you dont mind running wires, you can get a 3 to 2 trailer wiring converter. run the brake line from the bcm to the cap/converter that gives your brake signal, then just tap into the rear turn signals, and run that to the converter. that give you your brake and turn functions. and then keep the trailer plug harness for the ground and reverse wires. thats essentially what I did with thr diode harness. minus the turn signal functionality. once I removed the brake side of the c1r's from the stop/turn wires at the trailer plug, it works flawlessly now. the diode trailer passthrough harness still gives me my marker lights, the ground, and the reverse light power for the c1r's.
for example this curt 3 wire to 2 wire vehicle converter.
• Black is fused 12+ (might be able to grab from trailer plug, instead of going up to battery.)
• White is ground (which you can use the trailer plug in bumper)
• Bown is marker(again grab from trailer plug in bumper)
• Red is the brake wire from bcm
• Yellow is left turn from tail light
• Green right turn from tail light
• Reverse wire you can keep at the trailer plug too.
That way you have brake and turn signal for your rack, and the reverse aswell.
like I said minus the turn signal functionally, mine is essentially the same, just below the bumper, I did not use the turn/stop from the trailer plug, as that gave me the error(the trailer plug be looking for the left turn, and it seeing a brake signal lol) I use the bcm brake signal to trigger the brake function of the diode harness which would of been the left/right trailer stop/turn.
if that makes sense. lol
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20251105_161553_Samsung Internet
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20251105_163255_Samsung Internet
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20251105_163902_Samsung Internet
bigb
Tucson
2025 Ranger 2.7
My topper installer told me they are going to get brake light power and power for the LED dome light from the trailer 7 way circuit. If this is correct maybe I'd better have a talk with them.
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
if you get a leer from ford, they have their own harness available only from leer/ford. but a leer aftermarket upfitter apparently can not buy that harness, its exclusive for ford accessories. What I posted above is the body builder guide, that aftermarket upfitters have access to.
I like I stated above, I used the Diode Dynamics trailer plug harness and I was getting trailer bulb out warnings when I had my turn signal on, without my foot being on the brake, when I had my foot on brake, all was well, because the turn signal was backfeeding the other turn signal I think at the trailer plug. and I would have a trailer connected message, and had to "set up a trailer" to get my bliss working again, but lost my reverse sensors, and the "trailer would disconnect" evertime I would turn on my park lights with my foot on the brake, and stay disconnected until next time I cycled the headlight switch from on/auto to off and back on.
then I found the fbbg and ran a wire from the bcm to the back when I got my cap installed. my upfitter said they were going to do it anyways that way, so it worked great for me. I solved my trailer light errors, by simply removing the brake function from the trailer turn/brake plug and running my own brake line lol. And the upfitter got a easy install, gave them a deutsch connection with 3 6in pig tail wires, told them red was brake, yellow was battery, and black was ground, and put it where I wanted it, and how I wanted it. lol
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
bigb
Tucson
2025 Ranger 2.7
I took a peek today and saw the plug connector, I have all 6 wires on the feed side and nothing on the other side (I do not have the 120 volt option). So it would appear that all I need to do is pin that empty connector at the purple/brn & black/gray wires for my 12V outlet? Any idea what size those wires are and if they will support a 5 amp load with minimal voltage drop? If I had to guess they look like AWG 16 which doesn't give me a lot of confidence running a compressor fridge, unless the size increases on it's way to the source.
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed plug under bed2
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
when I looked at a 2024 RR August 2024, the bed plug has it at 12V 180W, that what 15amps? you can buy thr panel, but ford jacked the price up, they are also only on while the key is on, you can apparently change the timeout for the cig lighters/120v in forscan.
and you dont have the inverter? but have all the wiring? thats weird. lol look under the driver front seat and see if you have the inverter. do you have a 110v plug in the back seat?
on the 25's we only got the 110v in the bed, but the 12v is there 2 feet away. lol
Im thinking I might get the panel with my tax return the spring....
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20251106_153042_Gallery
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed 20240823_110122
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20251106_153617_Samsung Internet
Ford Ranger 2025 XLT with a A.R.E. CX Classic truck cap installed Screenshot_20251106_153548_Samsung Internet
