AdventureLab
- First Name
- Brit
- Joined
- Mar 14, 2025
- Threads
- 56
- Messages
- 930
- Reaction score
- 1,337
- Location
- St George, UT
- Vehicle(s)
- '24 RR
- Thread starter
- #1
Another new product release by American Adventure Lab – BRAPs (Bed Rail Attachment Points)!
This one has been a long time coming. It may not seem like a huge deal until you need to secure some cargo in an odd way – then you realize what a lifesaver these really are!
With the BRAPS installed, you get rock-solid top plates that instantly add secure attachment points to your Ranger’s bed rails. They mount in either the up or down position, use our dynamic spacer pack to perfectly match rail height, and provide a bombproof foundation for mounting chase lights, tie-downs, brackets, or our Bed Rack RAILS.
The cutouts in each top plate are shaped and sized specifically for ratchet strap hooks and bungee cords, so you can secure gear quickly without hunting for an anchor point.
Important note: BRAPS are just the top plates. They do not include the bolt-in Nut Plates. However, we designed them to work seamlessly with our Bolt-In Bed Rail Nut Plate Set (released last night). Together, they make accessory swaps unbelievably fast – you can move or remove your BRAPS in about a minute without crawling under the truck or fighting factory hardware.
Highlights:
https://americanadventurelab.com/product/ford-ranger-braps-bed-rail-attachment-points-full-kit/
The video below shows the BRAPs paired with our newly released Bolt-In Bed Rail Nut Plates for the Ford Ranger.
Highlights:
- 3/16" 5052 aluminum – lightweight, strong, and corrosion resistant.
- Configurable in up or down orientation.
- Dynamic spacer pack adapts to any stake pocket position.
- Cutouts sized for ratchet straps and bungees.
- Compatible with Bed Rack RAILS, Light Pod Brackets, chase lights, and more.
- Designed, built, and tested in the USA.
