24' RR shifted while driving
Ranger #1
Ranger
So after filling up about half hrs ago I was driving and noticed the dash switching driving modes automatically. It managed to switch to 4wd then 4wd low before I pulled over and put it in park. Once in park I was able to switch to normal and drove home. Lucky I was going about 15 mph... I couldn't find a thread like this but remember some discussion months ago I thought. Thanks
Hello everyone has anyone taken there ford ranger to a dealership or anyone that could tell you about this issue! And how to fix it!
cararch
James
San Marcos TX
Ford Ranger Lariat 4wd offroad
About once or twice a week, without touching the console or shifter, my 24 Ranger Lariat changes to sand mode and into 4WD high. It first happened in February but didn't repeat for many weeks. Now it's happening far more often. I have to stop, set the drive mode to normal, and only then can I change to 2WD. This Ranger came equipped with the electronic shifter. I'm not sure if there is a connection. I'm taking it to the dealership on Tuesday, 4 Nov.
Ranger #1
Ranger
Please keep us all posted!!
24RangerLariat
2024 Ranger Lariat
I just picked up my 24 Lariat from the dealer. They had it for 2 weeks and couldn't replicate the issue. This is the second time it's happened to me. The first, they were able to reload a module with a fault code. But he second time there was no code.
Another thread post a user said they kept a metal yeti cup in the rear cup holder whi lch maybe induced some kind of electromagnetic interference.
I usually have a USB-C charging cable laying near mine, hardly used, but always plugged in. Maybe that could be causing the issue.
Do any of you have similar circumstances?
I submitted a detailed complaint on the NHTSA website also, for more visibility.
Ranger #1
Ranger
Hello ,yesterday evening I was driving in town at a slow speed and noticed on my dashboard saw it was in 4H and my knob 4H light was illuminate ,I didn't even come close to touching the 4x4 knobs or the button that has the slippery, sports mode etc, called 2 ford dealerships here close to where I lived and they were totally puzzled like I was ,I have no answers, but it seemed like it wasn't in 4H from the truck was handling like it wasn't in 4H ,I have a gut feeling that the normal, sports, slippery mode button has something to do with this problem!!
I have a UPDATE took my 2024 ford ranger to dealer and they scanned it, this is what they found right wheel speed sensor was not properly reading right BECAUSE the right axle shaft bearing was bad ,(to much play) which in return caused the tone ring to be out of sync with the sensor, which is all part of axle shaft assembly could just change bearing and tone ring ,luckily I bought extended warranty, it would have cost $1500 without it
Ranger #1
Ranger
Couldn't * just change the tone ring and bearing had to replace the right axle shaft assembly is what I ment
Ranger #1
Ranger
I have a UPDATE, took my 2024 ford ranger to the dealership, (reminder) I had ABS light, hillside assist light, pre collision assit light come on several times think 5 times over a year also once the 4H light came on ,anyway I took my ranger to the dealership and they scanned it and found on the right wheel sensor was not reading that wheel right, well the axle bearing had a little wear on it which caused the tone ring to be out of sync with the sensor (tone ring slightly loose or wobbly because of the bearing, the bearing, tone ring is part of the axle assembly, had to replace the whole axle shaft assembly, luckily I had extended warranty 10 years 100k miles to cover about 95% of cost had a small deductible, it would have cost about $1600 if I hadn't had that
24RangerLariat
2024 Ranger Lariat
I dropped mine off at the dealership 2 days ago, they just called and said the traced the issue to the ATCM ( All Terrain Control Module). They're replacing it.
2017Raptor
Wethersfield
Great to know and in case it ever happens again i will mention this.
Tinfish
Southwest
I took mine in to the dealer but they couldn't replicate it and didn't have any suggestions other than it might be tied to a low battery. Since them it happens about once a month. I've always been able to switch it back to normal mode while still driving, though. I'm surprised this hasn't triggered a recall of some kind though. It's unsafe for sure.
NevadaBob
Nevada
2024 Ranger Lariat
2024 Lariat, 12,000 miles. Today I was pulling onto the freeway, at about 60 mph, and the screen says something like "4x4 shift in progress, please let off the accelerator to complete the shift", then it went into 4H with the rear locker engaged and in "wet/sippery" mode. I pulled off and it wouldn't go to 2H until I first changed the mode to Normal. Seemed fine after that. I tested it again by putting it in 4H, driving a bit, then switched back to 2H with no issues.
I also recently had a light come up that looked like stability control was off, or traction control was off, while driving at highway speeds in the rain. I read that it could be a wheel speed sensor issue. Maybe this is similar to what @Ranger #1 had?
AMGRAPTOR
FL
2024 Raptor Ranger
you have a 24 model. Wouldn’t that still be under warranty?
