24 STX w/towing pkg, Shudder under accel with camper attached
Morningpride
Philadelphia
2024 Ranger LT STX
Towing my 21 Gulfstream (3000 lbs / 20ft single axle.) After about 3 hours, when I stop, and begin to accelerate I get a harsh shudder. Makes no difference what drive mode it’s in. No SES. Once truck sits for a while and cools off, (disconnected) shudder is gone. This is our first long tow, and other than that, truck towed like a dream. We’re planning a 1000 mile trip with the camper next month. I can take it back to the dealer, but there not going to find anything without the SES on.
Ford Ranger 24 STX w/towing pkg, Shudder under accel with camper attached IMG_7246
The f150s had this problem a few years back and changing the fluid fixed it for some while others had to use shudder fix by lubegard
https://lubegard.com/products/isf/
My brother's truck was fixed by just changing the fluid
Morningpride
Philadelphia
2024 Ranger LT STX
Morningpride
Philadelphia
2024 Ranger LT STX
Update. Truck is at the dealer. Definitely a trans problem. They are pulling it tomorrow. ?‍♂
Morningpride
Philadelphia
2024 Ranger LT STX
Update:
Full rebuild. Found torn bushing in the inner drum and steel in the fluid. New clutches, solenoids and Torque converter.
Corvette, '24 Ranger
Unless they have a different a process than other large brands, the dealer typically diagnoses and may do light repairs, but will not rebuild in shop. Usually a new / reman trans is shipped from the manufacturer and installed. The old one is shipped back as a core.
Thats how my ford dealer does it
Morningpride
Philadelphia
2024 Ranger LT STX
I know our service manager very well. He asked if I wanted the Mastertech to rebuild it on the shop, or to order a reman unit. Given the choice, I’m not putting a reman in a brand new truck.
smith01
Smith
Dallas, TX
Sedan
Travel
This sounds like a torque converter or transmission shudder under heavy load.
The fact it disappears after cooling suggests it may be heat related.
Checking transmission fluid condition and level would be a good first step.
Also ask your dealer about software updates or known TSBs for this issue.
Best to get it looked at before your 1000-mile tow for peace of mind.
Morningpride
Philadelphia
2024 Ranger LT STX
Just to give you a follow up. The dealer completely rebuilt the transmission. Found a small amount of steel and a torn seal. Replaced torque converter as well.
Made the trip, 1200 miles each way. Shudder is still there, now even when trans is cold, and only with the trailer attached. I tried a lighter trailer (2000lbs) and it’s not there. Only over 3500lbs irregardless of if the weight distribution hitch is installed or not.
wow. so the trans is not up for heavy towing.
i towed a wrangler home monday and didn't have any shuddering but i only towed it 10 miles or so and stayed below 40mph. i know it weighs around 3200 though
ScottyRangerDanger
New York City
2024 Ranger XL 4x4
wait so you got a new transmission and its still doing it? did I read that correctly?
