gtistiffler
Keith
Panama City, FL
2024 Ranger XL 4wd
Technician
Installed my Christmas present just now. I’m impressed! Everything feels super solid. I ran the charging cable through an existing hole above the charging ports behind the radio and out next to vent. Was able to use a flexible claw tool and pull the cable through without removing any trim besides the one piece to install the mount. Even included the tools in the box!!
Ford Ranger Bulletpoint Phone Mount Installed IMG_1278
Ford Ranger Bulletpoint Phone Mount Installed IMG_1277
Ford Ranger Bulletpoint Phone Mount Installed IMG_1279
Looks good
embedded rock
Earth
Looks good.
Using the same system on my RR. Also had BulletPoint for my former Wrangler JL.
JimG
Jim
Scottsdale, AZ
2025 Ford Ranger Raptor
Looks Good. I have a similar mount on my truck, but haven’t run a charging cord up to it. I probably will now.
I did use some similar components and a holster to mount my 9mil to my seat. No holes and 1 bolt. Moves back and forth with my seat.
gonzo117
Bob G
Roseville, California
2025 Ford Ranger Lariat FX4 2.7L
Network Engineer
Hi Jordan,
This looks great and makes the weapon very accessible. Will this work in a 2025 Ranger Lariat? Can you put some links to the holster and other parts you used to do this? Thanks, Bob
gtistiffler
gtistiffler
Keith
Panama City, FL
2024 Ranger XL 4wd
Technician
JimG
Jim
Scottsdale, AZ
I posted how I mounted my gun. Look for 9mm pistol mount no holes.
John E Davies
Spokane WA USA
Retired aircraft tech
Nice job. Seems like your phone mount should have a USB port so you could use a 90 degree cable there, is that possible? That extreme bend is not good for the cable.
I have my gps positioned there, the AC vent discharge catches the bottom edge and cools the battery, if your phone gets hot, play around with the positioning. In summer my gps got so hot it shut down completely, this location fixes that problem 100%.
John Davies
Spokane WA USA
Ford Ranger Bulletpoint Phone Mount Installed IMG_2448
Ford Ranger Bulletpoint Phone Mount Installed IMG_2447
Sojourner
Maryland
2023 Ford Ranger XLT Tremor
Tackform, Bulletpoint, ProclipUSA. Use them all, love them all. Can't go wrong with any of them. Which I pick depends on what I'm trying to do and on which vehicle.
