- Joined
- Feb 27, 2025
- Threads
- 38
- Messages
- 1,161
- Reaction score
- 1,735
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
Also be wary of spring lifts destroying your Fox Live Valve shocks.
Eibachs or Geisers? NEITHER!!
Apparently, there's been quite a few F-150 raptors with spring lifts that over time have had major Fox Live valve shock failures and there are several reasons why described in the video.
So, my recommendation long term is either strut spacers (most ideal) or perch collars if just compensating for a little extra weight. I don't see the BR's and RR's shocks faring any better than the F-150's with spring mods.
But that little, tiny bit of rub doesn't look to be a meaningful issue, it's just a tad a full compression and tire compression, about as much as you can get. Maybe try using a little less off-set or narrower tires?
