433hz TPMS for newer Rangers
ummagawd
Tommy
Huntington Beach
26 Avalanche, FJ Cruiser
Been trying to figure this out for my new wheels and tires, figure I’d make this post to help us owners of newer RRs out.
Ford changed to 433 sensors sometime in 2025 (I’ve not been able to confirm build date, but best bet is to talk to your dealer and give them your vin).
Ford OEM part # = PR3Z-1A189-M
This is the safest option as far as I can tell.
But then I found a set from Ford Performance Racing that lists the 2025-2026 Ranger (and bronco, maverick,etc). And it’s much cheaper:
M1180-E And it includes a programming tool. But fords website says it does NOT fit, while other places like steeda and blue oval says it DOES fit.
Anyone know anyone on here running the M1180-e? My search resulted in nothing
**UPDATED LIST OF WORKING 433Hz sensors, as confirmed by other members**
PR3Z-1A189-M (Ford OEM)
M-1180-E (Ford Performance/Racing)
Autel MX dual-band
Sparky62
So Cal
I went through something similar when I purchased some '21 Tremor take offs.
Google seems to say M1180-E is the kit (TPMS's & training tool) where as PR3Z-1A189-M is the stand alone single TPMS single part number.
I wound up just going to local HB Ford dealership and because I bought my Ranger from them, parts dept gave me a little price break on PR3Z-1A189-M.
cb4017
Cliff
Northern NV
2026 XLT 2.7L FX4
I am. I bought the Ford Performance M-1180-E TPMS sensors for my 26 Ranger XLT. I think I got them from Steeda. The included programmer didn't do anything but after a few miles of driving the computer figured it out and they work fine.
Ford Ranger 433hz TPMS for newer Rangers 20260915_175305 (Medium)
got3fords
James
Central Va.
If you buy a set of take offs, can you reuse the OEM TPMS sensors that came with the truck?
cb4017
Cliff
Northern NV
2026 XLT 2.7L FX4
Sure, if they're the right frequency.
The wheels I bought had no sensors.
got3fords
James
Central Va.
Good info, but what I meant was, can you take the TPMS's off the wheels that came with your truck, and use them on the new rims, be they takeoffs or whatever.
cb4017
Cliff
Northern NV
2026 XLT 2.7L FX4
Yes!
Tire shops do it all the time.
I thought about doing that with my take-off wheels and tires but decided to keep them intact for possible resale.
got3fords
James
Central Va.
Yes!
Thanks, I am really interested in finding a set of lighter rims. The TPMS thing was confusing me.
ummagawd
ummagawd
Tommy
Huntington Beach
Awesome! And how many miles do you have on the M1180-E sensors and have you had any issues?
Thanks for chiming in! (nice steelies BTW)
cb4017
Cliff
Northern NV
2026 XLT 2.7L FX4
Got a few thousand miles on them now. No issues.
As I mentioned the programming tool didn't do anything but after about 10-15 minutes of driving they synced up just fine. Perfect since then.
I would buy them again if I needed a set.
jm29910
jm29910
I went through something very similar a few months ago when I changed my wheels and tires. I ended up purchasing Autel MX dual-band TPMS sensors on Amazon for around $100 for all four, thinking that would be the safest option since they can be programmed for either frequency.
I initially tried letting the dealer handle it, but honestly, they weren’t very helpful. I wasn’t willing to purchase sensors that might not work, only to end up selling them and buying another set.
During installation, the truck actually recognized the sensors at 315 MHz, but unfortunately, the tire pressures never displayed on the screen. We then reprogrammed the sensors to 433 MHz, and surprisingly, everything worked perfectly. The tire pressures displayed correctly, and I’ve had absolutely no issues since.
My truck was built in March 2025, and I can confirm that mine uses 433 MHz, not 315 MHz. It was honestly pretty confusing because the truck initially recognized the sensors at 315 MHz.
Autel and Schrader are both very well-known and respected brands in the TPMS industry. They actually manufacture OEM TPMS sensors for many vehicle manufacturers, so I personally feel much more comfortable using either of those brands rather than some of the no-name sensors sold on Amazon or eBay. My local tire shop recommended Autel because that’s what their equipment is designed to program, and they use it regularly on the vehicles they service.
One additional recommendation from my tire shop was to go with rubber snap-in valve stems rather than aluminum ones. Since I occasionally off-road, their reasoning was that rubber stems are much easier and cheaper to replace if damaged, whereas aluminum stems can be more difficult to repair or replace when damaged on the trail.
To my surprise, the four Autel MX dual-band sensors ended up costing right around $100 delivered, and everything has worked perfectly since.
There are other threads on this issue and I don’t think it was ever made clear when one frequency was used vs another (I started one of the threads when I bought a second set of rims and needed new sensors). I’m among those who bought autel sensors they are dual-frequency and they work fine on my method rims, while the stock rims and sensors have snow tires and I have no issues switching between the sets.
ummagawd
ummagawd
Tommy
Huntington Beach
thanks everyone for chiming in, updated the OP to help future 433hz vehicle owners out
