Alignment printout after 2 inch leveling kit?
Nectrium
Marco
Sacramento California
2024 Ford Ranger XLT FX4
Out of curiosity drop your alignment printout sheet after the 2 inch level, debating if I need to throw upper control arms to retain proper suspension geometry. Thanks!
GLW
Missouri
What does “ throw upper control arms” mean?
I had a two inch leveling kit installed on my 24 RR with new Method 703’s (+35) on stock tires. Had my alignment done and wheel rebalancing- TWICE.
I think I have ruined my truck for a cool look.
My next move is to have a road force balancing to see if that will rid the highway speed steering wheel vibration.
I love the look of the front leveling lift and the wider stance of the 703’s but it’s not the same truck.
So, if “ throw upper control arms” helps me sleep I’m all ears on what to do next.
Nectrium
Nectrium
Marco
Sorry I meant install aftermarket upper control arms. And they are meant to restore proper caster and camber angles, alongside increasing clearance and improve suspension articulation. As for your case roadforce balance to rule out a bad tire or tires.
i have a 2.5 and no shakes or vibrations. i installed it in the driveway and ford aligned it for me when i took it in the next day. they said everything was good and gave me a print out but i have to try and find it
The word on the street is that you don't NEED new UCAs for anything under 2.5" level/lift. Anything more, or if you plan on serious off roading requiring high articulation, need UCAs.
GLW
Missouri
That’s what I’ve heard as well. I’m going to get a road force balance next week. Hopefully that will fix. If not I have no idea on next step.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
This is what I requested they do after my 2" lift and 35s
Ford Ranger Alignment printout after 2 inch leveling kit? 1761857072316-9x
Do the 19-23 Upper arms fit 24-26?
I am guessing, no. Ford parts list different PN for 19-23 and 24-25.
After markets also separate Gen5 and Gen6, and Gen 5 you have to specify if you have cast steel or cast aluminum knuckles.
geno87
2025 Ranger STX 2019 F250
thanks for the super fast response.
