Anybody put Timbrens on their Ranger Raptor yet?
Rw6735
Raptor Ranger, or Ranger Raptor…whatever
I have a 2024 RR. The driver side bump stop went on easily and even with the add’l spacers, I have 1.75” of space between the frame and the bump stop. The passenger side, however, looks to require that I use significant force to make the U-bolt fit around a reinforced part of the axle. Anybody figure out a graceful solution before I start pounding?
Rw6735
UPDATE: Called Timbren sales/tech support and confirmed I have the right package. The passenger side u-bolt required just a little elbow grease, some love taps with a hammer, and some blood from my forearms (I was too lazy to pull the wheels), but they’re on. On both the left and the right, I had to slide the bump stops as far out as possible to get the greatest amount of surface contact with the frame while the passenger side had a little less.
With 1.75” of clearance between the top of the bump stops and the frame rails, I didn’t feel the difference at all on my old suburban roads here in Plano TX. Once the trailer was hitched up, they had just a little squish/contact with the frame rails so I feel better about the load on the rear end now.
The Raptor has enough engine, cooling, and axle to pull heavier loads than the standard Ranger, but those squishy rear shocks that let us land 80’ jumps need help when weight is applied! Happy with the money spent on this.
kickingaz
New River, AZ
2026 Ford Ranger Raptor - Carbonized Gray
Self Employed
Just a word of caution, even though it is capable of pulling heavier loads, it is still only rated at the factory specs and you could be held liable in the case of an accident towing over weight. Mind you, I am not the towing police, but just a word of warning.
lancerdood
Lance
CA
2025 Ford Ranger Raptor
The standard Ranger is rated at 7500lbs towing capacity and the Raptor is 5510lbs - FOR A REASON......and it's all about the advanced suspension. Even though the Raptor obviously out performs the standard Ranger in every way and has the HP, it wasn't built for towing heavy loads. It wouldn't be wise to circumvent that unless you want to start replacing full suspension parts like buying new struts and springs....thus defeating the entire purpose of the truck.
If you wanted to tow more than 5510lbs then maybe you should have bought a different truck.
Rw6735
You made several assumptions there, lancerdood. Nowhere did I state I was pulling more than the truck is rated for. Also, “you should have bought a bigger truck” are words easily heeded when one has lots of money. In years past, I too had such an ego and a misunderstanding of the world around me. Now that I’m divorcing and all my money goes to attorneys and my STBX, I can’t buy a bigger truck. Think before you type something. Not everybody is living your life.
lancerdood
Lance
CA
Actually I’ll retract my previous statement of “you should have bought a DIFFERENT truck” as I’ve been down the D road & paychecks handed over to law firms….so admittedly I misspoke.
BUT… I do not have an ego or misunderstanding of the world, especially the one around me.
Have a great weekend!
