spack
chad
chester springs pa
2018 ford raptor
physycist
While this article explains what the cam phasers are and that there is an issue, it does not explain why there is an issue. Is this a quality problem? Is there some revision issue? Is this an issue at assembly?
This is copied from a post I did on the raptor Forum called phasers: From the Top. I've tried to shorten it a bit. It's still long winded and yet there is more to say. In short I believe this is the closest I've seen to actually identifying the root cause
The basics:
Cam phasers alter the position of the camshafts relative to the crankshaft and thus when intake and exhaust valves open and close relative to the piston positions. Without phasers this relationship is fixed, which is how things used to be. Phasers alter when fuel/air starts and stops entering on intake, and when exhaust starts and stops exiting on the exhaust cycle. Changes to the camshaft’s position relative to the crankshaft wouldn’t be necessary except for a couple of qualities of air. It’s springy (compressible), and it has mass. Basically it resists movement when stopped and once moving, it resists stopping. And these characteristics change based on temperature and pressure. Even if the characteristic of air didn’t change, as engine RPM increases, the time air takes to enter and exit the combustion chamber is more or less bounded. But the time allowed for entry and exit gets smaller with higher engine speed. Delay of air movement becomes a bigger percentage of the engine cycle at speed. Throw in a turbo charger, and you have another variable that influences how the air moves and how long it takes. Change exhaust headers, and the exhaust exit time changes. There becomes a nearly infinite set of timings for optimum performance. And one persons performance may be a California dude’s pollutant. The cam phaser is one very limited way of dynamic tuning to achieve some set of performance goals. I say limited because there are many more things we could do with valves than decide when they open and close; how far they open for example. And with a phaser, if you open a valve sooner, you also close it sooner. What if we wanted to open it sooner and close it later (duration). Can’t do that with a phaser. But a phaser is an amazingly simple device that allows the camshaft relationship to the crank to be controlled. Unlike air, oil is not compressible. The cam phasers used on most modern cars use oil pressure to turn the camshaft back and forth, through a limited range, inside the camshaft sprockets. By pushing oil into one chamber (or set of chambers) in the sprocket, the camshaft itself can be pushed ahead (advanced) past its current position relative to the sprocket and thus crankshaft. By pushing oil into an opposing chamber we can push the camshaft behind (retard) its current position. If no oil is allowed in or out, the camshaft stays glued to the sprocket. And that’s all there is to the basic device. A couple of oil ports in and an exit or drain port out. Oh and there is a locking pin, sigh…. To take care of startup when there is no oil pressure.
The control system is detailed in the drawing at the bottom of this post.
At its core is a PID, which stands for Proportional Integral Derivative controller. The PID represent closed loop control. Its purpose in life is to keep its 2 inputs as close together as possible. One input, the desired camshaft angle, which is the SetPoint(SP) in PID lingo, comes from software which uses all sorts of other inputs to decide what the cam angle ought to be. The other input, the actual camshaft angle, which is the Process Variable (PV) in PID lingo, comes from a position sensor on the camshaft. The PID assures that whatever the software wants, the software gets. PIDs are everywhere in car control. Cruise control is PID controlled. The Setpoint being what you set the road speed to, and the ProcessVariable, coming from the same sensor that drives the speedometer. The output of the PID drives the accelerator pedal. If you encounter a hill and the car starts to slow, the PID output increases, producing more engine power, until the speed increases. In the camshaft case the output of the PID is converted into a pulsed output, which drives a field effect transistor, which drives a solenoid, which drives a spool valve, which drives oil into and out of the cam phaser, which drives the cam’s position relative to cam sprocket, and ultimately relative to the pistons position. A bit more on that later.
So here we go with more Ford specific stuff….
On start up and idle…
The Exhaust Phaser’s default lock position is fully advanced.
The Intake Phaser’s default lock position is fully retarded.
Why those are the default positions is not the focus of this post. That’s what they chose.
From a control point of view, the above has implications as follows. By arbitrary definition, advancing camshaft timing is always decrementing in degrees and retarding is always incrementing, for both exhaust and intake cams. Again arbitrarily, 0 degrees is always the lock position in both. So in the exhaust case the numbers will start from 0 degrees (locked) as the most advanced position and increment from there to retard. The numbers are never in the negative range. Intake also starts from 0 (locked) but as the most retarded position. From there the numbers go negative to infer more advance. The numbers are never positive. These are indeed arbitrary definitions but cam position will be reported this way by an ECU monitoring and configuration tool like Forscan. They are also the language the PIDs speak.
Solenoids are electrically actuated devices used to control the oil valves that influence oil flow to the chambers within the camshaft sprockets. Just like the lock pin position has implications to the positional definitions, these starting positions also have implication relative to the control solenoids and what the PWM duty cycles mean. PWM stands for pulse width modulation and refers to the electrical signal that the ECU feeds the solenoid to control it. It’s measured in percent and is another informative variable one can see with Forscan. At a minimum it tells us what the ECU and thus the PID is trying to tell the solenoid to do; like advance, retard, or hold steady. From a control standpoint, an unpowered solenoid should match the lock positions. An unpowered solenoid is by definition, 0% duty cycle. The phaser default lock positions imply that duty cycle means something different between exhaust and intake. 0 duty cycle means full advance for exhaust because that is where the exhaust phaser is in its default position. Incrementing duty cycle form there must mean to retard. Conversely, 0 duty cycle means full retard for intake. Increasing duty cycle from there must mean advance. This brings the locked positions into agreement with an unpowered ignition system about to start and it brings percent duty cycle in agreement with which direction exhaust and intake can go from their respective home positions with increasing duty cycle or increasing PID output.
A little bit more on Solenoids: Control of the oil into the advance and retard chambers of the phaser is controlled by selecting oil pressure to one side or the other through a spool valve. The spool valves turns linear shaft valve movement in or out, into selection of the phaser chamber to push oil into and allow oil out of. A solenoid creates the linear force into the valve, and a spring returns the valve when that spring overpowers the solenoid. The higher the duty cycle the greater the force. A solenoid is a variable force actuator, not a linear position actuator. Therefore a particular duty cycle does not imply an exact oil flow in either the advance or retard directions except at extremes or relative to something else. In fact the implementation of solenoid control will not be designed such that 100% duty cycle is legal. From a Forscan point of view, percent duty cycle is a magnitude reference but other than low duty cycles and high duty cycles, you can’t really infer advance, holding, or retard directly. You can determine, from looking at whether advance or retard angles are changing or not, as to what the holding duty cycle might be, and once that is known you can determine advance or retard intention and with what relative magnitude, by using the holding percentage as your reference. In other words, is the duty cycle above or below the holding reference and by how much?
The lock pin. At engine start, the lock pins hold the camshafts in their 0 degree, default positions; max advance for exhaust and max retard for intake. After startup, the ECU decides when to unlock them. Certainly after there is sufficient oil pressure to do so. How is the lock-pin unlocked given these starting points? The lock pin eject is a parasitic action in this architecture. Most car manufacturers who default lock at one extreme or the other, don’t have independent lock pin control and the complexity that might bring. Instead the architecture uses a method which is dependent on the starting position. With exhaust, since we start from the lock position as the most advanced position, it is the action of retarding oil pressure which will eject the pin. Thus there is a small oil channel from the retarding chamber that feeds the lock pin well. As the Solenoid receives its first command to retard, oil pressure which is meant to cause retarding action also pushes the lockpin out of the well. With intake, since we start from the lock position as the most retarded position, it is the action of advancing oil pressure which will eject the pin. Thus there is a small oil channel from the advancing chamber that feeds the lock pin well. As the Solenoid receives its first command to advance, oil pressure which is meant to cause advancing action also pushes the lockpin out of the well. In both cases there is a little bit of a battle going on between the pin going upward out of the well to unlock, and the advance or retard action creating a shear force on the pin and against the lock pin well, fighting the lock-pin’s upward movement out of the well. This is a source of wear on one side of the lock pin well; the side away from the default position. It is an architectural feature and quite frankly, a weakness. The telltale sign of this wear is a smoothly ramped well pin hole rather the a sharp cylindrical hole. Once sufficiently warn, the pin will no longer lock the cam and sprocket together. This is particularly apparent if the engine has been sitting long enough for oil to have drained out of the cam sprocket chambers. With no locking capability the camshaft bounces back and forth from one chamber limit to the other before oil pressure builds enough to allow PID control of cam position.
The phasers have bias springs. The springs bias the camshafts towards the advance direction. How those are calibrated I don’t know but probably against the aggregate force of driving the cams against the valve springs. The intent would be to make the oil pressure required to advance, similar to retard. There is an asymmetry in that they would help the exhaust cam head to the home position and pin lock on engine stop. But not for intake. This is probably immaterial. But the point is, they are not “parking springs”.
The difference between the MLZ and HL3Z…-CD parts….
There has been lots written about Ford’s cam phaser problems…. As though it’s a Ford issue. Try Googling CAM RATTLE followed by the car manufacturer of your choice. Toyota, Honda, Hyundai, the list goes on. You won’t come up empty. It has a lot to do with the fact that almost everyone has a phaser related to the same patent, and that patent is to do with the lock pin ejection method when using a vane and chambers phaser as discussed in this post. There is also information on this forum that says you need to have the MLZ parts to have permanently fixed the potential phaser issue. I originally question that for the following reason. But my mind has since changed as I’ll note later. Every picture I have seen of a failed HL3Z part is version -CC or earlier and the CD parts have an interesting change. Having said that, there are differences between the MLZ part and the HL3Z … -CD parts. They are NOT architecturally different. In other words, lock pin ejection is still linked to exhaust retard or intake advance and the force battle that architecture creates against the lock pin well sidewall. What is different comes down to 3 things, The MLZ part has more depth axially than the HL3Z parts which means the advance and retard chambers have more volume and create more advance or retarding torque in the MLZ parts given the same oil pressures. Although this is somewhat offset by the fact that the chamber diameter across is less than the HL3Z parts. The bias spring constant on the MLZ part is higher. The second difference is in how the lock pin well is fed with oil to eject. In the MLZ part, the channel that feeds the well is in the vane and not in the well plate. The well sits by itself with no channel directly connected to it. The third, and I think, key difference is in the other end of the locking pin where the locking pin spring is anchored. Both designs hold the return spring centered with a plastic cap/pin. In the HLZ part this plastic cap rides on the back plate of the phaser. This backplate is in nearly constant motion relative to the cap. In some failed parts, this plastic cap can be seen to have disintegrated. If that happens the spring can become entirely misaligned and not able to seat the locking pin in the well with sufficient force. This will in turn cause the pin not full engage and further well wear occur as it pops loose. In the MLZ part, this plastic spring cap is not in contact with a moving plate. That is potentially huge. There is also an immaterial visual difference between the HLZ and MLZ parts, There is a bias spring cover which is press fit on the MLZ parts. This serves to keep the bias spring in place because the studs the springs anchor to, don’t have capture heads like the HL3Z parts. The HL3Z -CD parts are distinctly different than their earlier counterparts in how the lock pin well is constructed. Previously the well did not have a sidewall where the oil channel fed it. Now it does. So presumably, less oil pressure will float the pin and the pin is more symmetrically supported when in the well. But the overall architecture between both phaser types is unchanged. If the plastic cap is not the issue, and the below referenced patent is, the the latest HLZ-CD part will address the problem. If the cap is the problem, the HLZ part will not fix the problem. I have see one failed instance of the latest HLZ part failing because of the plastic cap.
On the subject of the lock pin architecture, the following patent https://patents.google.com/patent/US20050188933A1/en refers to an improvement over prior-art and that prior-art is the Ford design and Toyota design and everybody else’s design. They claim the prior method is prone to trouble because of the shear force versus ejection force mentioned in this post. Their solution is to feed the lock pin well from both retard and advance chambers thus allowing the solenoid to dither and feed both wells at the same time to cause pin eject. This results in overall well pressure without advance or retard torque, leaving only the lock pin to experience ejection pressure. After unlock the phaser can be advanced or retarded, avoiding the shear force on the pin well. This patent is quite elucidating in that it appears to be well known in the industry that the prior-art has a very specific flaw that creates a problem just about every car manufacturer has seen to one degree or another. Yet the industry has been focused on making the prior-art work for longer, rather than addressing the root cause.
Although this is possibly the cause of the Ford EcoBoost issue, I think the primary cause is loss of the lock pin's plastic return spring cap due to wear on an initially not well lubricated, moving surface.
Ford Ranger Article: Cam Phaser Issue Explained 1727880847585-z7
Ranger #1
Scott
New Mexico
Ranger
Guys several posts on here about the Camn Phaser issues, I have mine that started at 900 miles, dealing with Ford on next move. It requires a full motor pull to repair. My issues is, if they do it and put the same part in, what is the purpose? I am trying to get a completely new motor dropped in, we shall see what they do. I also have the front drive line whistle that started, again posts here, appears to be the front drive shaft, that is the next issues to resolve. So sad, we spend the big money for a performance truck, and have issues before our first payment is due! Ford customer service was no help at all, heads in the sand!
What size motor do you have in what model of truck!! I have the 2.3L I4 ecoboost engine in my truck!!
Rangerjimm
SC
2025 Ranger Lariat 2.3
You are right, and I agree, BMW does seem to have it sorted today. Not sure why ford can't figure this out.
It's function is the same, but how the function is performed is very different. BMW uses a helical gear to advance or retard the cam timing. The helical gear is moved by a plunger that is controlled by oil pressure, but the point is: vanos does not require a locking pin to keep the variable timing components from slapping around at startup.
BMW VANOS did have a nasty habit in the 2000s of snapping the bolts and in-turn grenading the engine. I had and e46 M3 for awhile and changed the bolts as a precaution. When those bolts snapped, the pistons and valves would crash.
Silver lining: when the ford phasers fail, the pistons don't meet the valves :rolleyes:
With respect, I say nonsense about BMW having it all figured out. I've had three BMW cars/suv's, and each had serious vanos-related issues in their respective lives. The 740iL and x3 were usually vacuum-related, and while the hoses and o-rings were cheap, BMW seems to design their cars and engines with their weakest parts in the center, and bolt/attach everything else around it. Labor costs for the fixes were @$#^ing ridiculous. A 2011 535 had more serious issues with some bolts just deciding to take the day off while I was navigating manhattan traffic in rush hour. BMW doesn't have it figured out, and to be fair, they might engineer things well but then farm out procurement and manufacturing to the lowest bidder resulting in a crappy product.
alrashid2
PA
Looks like my 2.7L 2026 with 2,006 miles on her has cam phaser failure
No issues here at 28k miles on my 3.0L RR, my buddy has a 21' ST with 130k miles he beats the living crap out of, he has a bit of elevated oil consumption now from ring wear (moderate), but never any phasor issues.
In 2021 Ford updated the 3.5L phasor design, specifically the locking pin hole machining, I posted an article on that a while back, but here's the difference:
Old and busted (you can see where the pin wears the lip, then jumps over the locking channel):
Ford Ranger Article: Cam Phaser Issue Explained 1790767450100-ag
New hotness:
Ford Ranger Article: Cam Phaser Issue Explained 1790767493268-zu
However, I believe the 2.7L and 3.0L still use the old design and were never updated because they typically don't have those issues (at least not nearly as common). This could be due to volumes of vehicles sold with those engines or perhaps differences in the valve timing during start-up, use conditions etc.
I believe this problem is related to three things in varying combinations, 1. driving conditions (for mostly highway, I think it's less likely to occur) 2. Using Ford's sucky ASS feature instead of disabling it, which is also problematic on MANY other vehicles and 3. part quality / design.
I never installed an ASS delete on my RR, because I got so used to a two-button press to start up my truck (start / stop button + ASS disable button). I just automatically press one, then the other or save a profile to my R button as you can also defeat the sucky ASS feature by saving an R profile with it off.
Nothing wrong with the using a delete kit too. Also, I do want to note that there is zero harm that I'm aware of to running the engine with bad phasor pins. It just sounds like a diesel during the first 3-5 seconds of start-up until the VTC solenoids have oil pressure to stabilize the phasor positions, then the issue goes away.
At the end of the day, it's a nuisance problem just like turbo waste gate rattle that is present on EVERY EcoBoost and turbo engine, you just hear it more on some than others depending on where the turbo is. For TT V6's, the turbos are much closer to the wheel wells, so you tend to hear it on those, but for the 2.3L, its more compact and upright, so the turbo is deeper inside the engine compartment and it's harder to notice.
Nuisance Issues:
1. Phasor rattle during start-up
2. Waste gate rattle that's often mistaken for phasor rattle, kinda sounds like more of an erratic tapping sound (mine does this and has since new, typically it's load dependent, so in neutral, doesn't do it, but if I'm in drive with the AC on, I can hear it intermittently).
3. Noisy HPFP and injectors that sound kinda like little marbles rattling around your engine (my Mazda's sound like this on cold start, in the winter they can be very loud and almost sounds like something is wrong, but none of them have any issues, never got any worse either even on our highest mileage one with over 125k).
Now if you got the phasor rattle on a brand-new or new-ish engine still in warranty, by all means, I'd have it fixed, but once my engine is out of warranty, IF I develop that problem, don't care. I just ignore it since the truck will run fine. I've seen F-150 owners post videos of 3.5L's with phasor rattle that started early on, they just kept driving the truck and 190k miles later, still running fine, but still sounds like a diesel during start up lol.
But I highly suspect that Ford's sucky ASS feature is a big part of phasor rattle. Think about it, you have 10x the start / stop sequences, even worse if you do a lot of around town / city driving and don't disable the feature. If you eliminate that feature, suppose they only last 60k with that feature on, disable it and the same part will last 10x longer...unless there's a mfg. defect.
alrashid2
PA
Thanks for the writeup! Since I'm only at 2,000 miles on my new 2026 2.7L I am having the dealer fix... they didn't care to see my video and said they'd have to verify themselves. Letting it sit overnight, got a loaner, and they'll diagnose and call me tomorrow. We'll see.
Loudpa
Pretty wild that Ford still has issues with cam phasers. Their system works very similar to BMW VANOS that's been around for 30 years now. BMW has had it sorted for 20+ years now.
Yes! I replaced the VANOS seals in my 1999 E39 years ago.
Rangerjimm
SC
So sorry you have this. I believe the engine has to come out. So much for those that say the 2.7 doesn't have these issues.
