Audio
kemwm38
New York
2022 Ford Ranger Lariat
Installed a audio control Lc7i to run to aftermarket amps. Are resistors required between B&O amp and Lc7i ? And if so what would be recommended ?
Max_P
Spain
Ranger Raptor 2023 - Lighting Blue
I will have the 2023 raptor here in a couple of days and I will do a complete audio swap, do you know if the B&O amp provide the exit for all the speakers? But I will probably replace all the cables as well with 12 AWG
kemwm38
New York
All but the tweeters. They come off head unit .The sub is dual voice coil but only need one pair of wires from amp, not all 4
Murraydog
Simon
Bangkok
2020 Ranger Raptor
Audio control sells load resistors, not sure if you need them though, maybe try without first and see if any issues
Callan
Callan
Australia
2023 Everest platinum
I would consider getting a NAV.TV A2B interface. Gives a true line out (optical or RCA) from the system and eliminates the B&O amp. Converting speaker level sucks.
kemwm38
New York
Got rid of the audio control line out converter. Is the nav.tv A2B a plug and play or is a computer and program required ?
goalieThreeOne
Memphis
2022 F-150 Raptor
Mostly plug and play. There is some programming but it’s just setting dip switches.
kemwm38
New York
Appreciate response. Computer involved I’ll have to pass. Local car audio places charge $100 an hour. All I have is iPhone, won’t invest in laptop
goalieThreeOne
Memphis
2022 F-150 Raptor
I don’t think you understand what I said. I said there is some programming but it’s just dip switches. Dip switches are small switches on the side. There is no computer. You just need to flip one or two to tell it what car you have have what type of output you want and that’s about it.
kemwm38
New York
Okay, now I get it. I call them jumpers, my bad
kemwm38
New York
So what I have is 2 Morel 4.40 amps, Elate carbon 6’s and mm3 mids with Morel 450 tweeters. Have Wavetech line converters and using Morel mxt 380c crossovers. Don’t see any need for any kind of signal processors. With the lossless music steaming and the fact that Morel knows what they are doing any kind of expensive add ons seems like overkill to me but had to ask.
Callan
Callan
Australia
Actually NAVTV removed the dipswitches in favour for usb. You now change the settings via a web interface so a PC is required.
goalieThreeOne
Memphis
2022 F-150 Raptor
Then I apologize to OP because I thought it worked like the PacAudio units.
Thanks for the information.
