Bed rail tie-down options yet?
1986YellowRanger
Ohio
Edge
I’m looking for something like this, but so far it doesn’t seem like anyone is making them for the new Ranger… Any ideas other than a DIY hardware store solution?
Ford Ranger Bed rail tie-down options yet? IMG_1432
Torr_ATL
Athens, GA, USA
2024 Ford Ranger XLT 2WD
Here is my DIY solution.
I purchased this kit: https://www.uscargocontrol.com/products/2-track-anchor-point-tie-down-kit-black
Then bolted the anchor points down using one of the factory holes and one drilled hole. Worked great. The rings are easy to snap in and out and the factory covers go right back on when not using the rings, so it doesn’t interfere with my Diamondback bed cover. Will probably add more L-track to the front bed rail at some point.
Ford Ranger Bed rail tie-down options yet? IMG_1757
Ford Ranger Bed rail tie-down options yet? IMG_1758
Ford Ranger Bed rail tie-down options yet? IMG_1759
Ford Ranger Bed rail tie-down options yet? IMG_1760
i would like something that doesn't require drilling. i can walk to the ocean from my house and anything that ever gets scratched to the metal, even if you try and treat it and touch up paint it, ends up rusting because of the salt in the wind. i think @AdventureLab should make something also
FWIW acf50 or a lanolin-based spray/undercoat should be in your arsenal and used regularly.
that would be perfect, to me. i use the factory loops that stick up all the time so having other ones to go to would be great
AdventureLab
Brit
St George, UT
'24 RR
Question for you guys.
Would you want to buy 6 of these, or 4?
We're going to be able to leverage a lot of what went into the design of the spacers for our bed rack system, but there are somethings that are position dependent, so if we can get away with filling everyone's needs with the four corners, that would make the product much more simple. It's going to have a huge feature that you guys will really like, but if we have to do the middle connection points, that will complicate it a little. It'll make more sense when I share the details.
1986YellowRanger
Ohio
Edge
Four would be fine for my purposes. Thanks!
four would be fine for me too. and if ford made most of hte holes in the bed the same size and thread, that would be even better as they can be moved to where i need them
DutchRanger
Mark
Austin
24 ranger xlt fx4 2.7l
Sounds like 4 is the way
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I only have my middle available currently so if a 4/2 split was an option that could be the best of both worlds, not knowing the details though not sure if that would be feasible but seems that split option could serve all?
