Bed rattle and crack
Rdbaja
Ron
Cabo San Lucas
2022 Ranger Raptor 2.0 diesel
Fish
My 2022 Ranger Raptor diesel has 7,200 miles. I recently noticed a fissure stress crack in the bed exterior corner. Horrible rattle is coming from inside the bed panel. Obviously a weld or brace has broken free. When I took it to dealer they said it’s caused by my 100lb fiberglass camper shell ??? Not covered under warranty. Anyone experience same crack ?
Ford Ranger Bed rattle and crack IMG_5408
Ford Ranger Bed rattle and crack IMG_5409
Rdbaja
Ron
Cabo San Lucas
Fish
I did not
Xyotafella
Derek
‘23 Tacoma Off Road
Machinist
If you have to install special braces for a shell…..that’s comical. Seriously!?
LFRR13
En Why Sea
Honda Ridgeline
All has to do with dimensional rigidity. The cap may prevent the flex accounted for within the bad design, thus directing such forces to the path of least resistance. If the OP didn't do what is required to run the cap...then the OP is in error. I find nothing comical about this.
Now, if the cap was sold & installed by a dealer...then that's something entirely different.
Xyotafella
Derek
‘23 Tacoma Off Road
Machinist
I don’t care what the manual says and it’s not comical it happened. Shouldn’t even be an issue. I’ve never heard of having to add a special brace for a shell. Not much weight that is distributed evenly as well….thats just crazy to me. Ford should add the braces at the factory or design the bed differently. That’s a big flaw and that bed is f’d
Harrington
Elkhorn, WI
2016 F150, 2024 Ranger Raptor
Does anyone know if the J Braces are available here in the states yet? I plan on putting a Soft shell with a rooftop tent on mine and want to get those right away.
Rdbaja
Ron
Cabo San Lucas
Fish
Dealer is saying that the clamps holding on the 110lb fiberglass shell don’t allow the flex in the steel bed ??? I’m still claiming a shit weld broke free. You can off road and jump this thing …..but can’t have a shell ??? Hmmmm
looks like I’ll be paying a body shop to fix what they can, the crack is getting bigger daily
Rdbaja
Ron
Cabo San Lucas
Fish
This is a performance off road truck ?? I live in Baja, this truck is not Baja worthy, already had the turbo hose fall off intake, lane sensor problem and now this. I have 7,814 miles on the truck and bought it new. I hat a 2017 Ranger xlt 4x4 3.2 diesel beast I should of never traded for this weak Raptor Ranger
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
This is the 5G Ranger not the 6G so we are talking about a different car here.
None the less, the need for the J-brace on the 6G is pretty disgraceful. I had the J-brace installed within about 3 weeks of taking delivery of mine - just in case.
Gator21
FL
F150 & Wrangler
The Ranger Raptor 6G debuted in Australia and probably other markets as well in 2022, so the original post would be in reference to the 6G.
kaycott88
Karah
Pennsylvania, USA
2024 Ranger Raptor, 2020 F-150
Is the J-Braces you bought a Ford part? If so what's the part number? Thanks.
CrustyNoodle
Peter
Mechanical Engineer
Yep they are a Ford part however I had the dealer install them so I didn't have to order them specifically and hence don't know the part number.
However, I do believe that the Ranger Raptor uses a different part number than the regular Ranger.
It was not particularly expensive to have the dealer install them - maybe $300 but it is pretty annoying that they don't come from the factory with enough strength to use the tub the way most people are likely to use it.
