Bigger tires 2 inch leveling kit
TIM'S FFR
Arizona
2024 & 2025 ranger XLT
shop foreman
Has anyone put bigger tires on their truck with just a leveling kit
I have 255-70-17stock thinking about 285 70 taller and wider correct
NM Mike
I’m assuming your truck is not a raptor, with 255/70-17’s on it. I haven’t lifted/leveled my 25 xlt (yet), but have been reading posts about lifts and bigger tires on this site. From what I gather, you can go up to 275/70-17 tires with a 2” lift but you will need wheels with more offset (35) to avoid tire rub to go up to a 285 tire. Depending on the lift and tires picked you might still get minor rubbing with the 275’s at full lock.
Again, I haven’t done this, just read other’s posts. Try doing a search here and see what others are doing.
TIM'S FFR
TIM'S FFR
Arizona
shop foreman
2 inches in the front and 2 inch spacers all around
Ch&ler
2024 Ford Ranger XLT 4Ă—4
Server
You are correct that they will be taller and wider. You're definitely going to need a lower offset wheel. I have +25 wheels and only 275s with a 1.5 inch leveling kit on my set up and the only rubbing I get is in reverse at full lock. 285s would most likely have a little bit of rubbing elsewhere. I think the 275s fill out the wheel well really nicely.
TIM'S FFR
TIM'S FFR
Arizona
shop foreman
Thank you
i think my father in law has 285 on his xlt. i know they are alot bigger then the stock xlt 18 inch tires on mine
djrainmann
Aaron
North Las Vegas
2025 Ford Ranger Lariat Fx4
LMS Admin
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
I just did 285/60R18 with a 2.5 Eibach coilover lift and new Rims with -12mm Offset (I wanted more poke since I am adding the fender flares) and I rub just barely on the front flap at full lock in reverse. No rub on crash bars.
PS - I also have brand new Bora 1.5inch Spacers for sale if you go the spacer route.
https://www.ranger6g.com/forum/threads/brand-new-4-bora-1-50-inch-wheel-spacers-275.26885/
Curious to see how this offset looks. Can you post a picture of your truck?
djrainmann
Aaron
North Las Vegas
LMS Admin
@HighDesertRanger
WHEELS - Fuel Wheels Rincon Matte Black with Gloss Black Lip
6-Lug Wheel; 18x9; -12mm Offset
TIRES - 285/60R18 Yokohama Geolandar A/T4 G018
This is without the fendor flares as I am waiting for them to be delivered.
Ford Ranger Bigger tires 2 inch leveling kit side_1_tires
Ford Ranger Bigger tires 2 inch leveling kit side_2_tir
Ford Ranger Bigger tires 2 inch leveling kit PXL_20260224_231129043
ryanO
Ryan
2025 RangerXLT
Sales
@HighDesertRanger
I noticed you have the bed steps, what FF did you go with? Not all of the available ones work with the steps.
djrainmann
Aaron
North Las Vegas
LMS Admin
ryanO
Ryan
2025 RangerXLT
Sales
