FullSend
Ninjaneer
Posting for those interested in this cover and would like to see how it looks installed. They released it around Thanksgiving and I picked it up during their BF sale. Straightforward install, although it took some more time than the one for my F150 raptor. Some things to note:
At this time, SB won't pre-install the Yakima base tracks for this cover (they do for the F150). Not difficult, but with the short bed, you need to be precise where you choose to drill your holes to not hit any hardware underneath.
My cover was sent with too short of lock-rod guide brackets and I ended up cutting a small notch into the bedrail (plastic and Steel part) for it to clear to lock. I should have reached out to DB before doing so, but with it being the Christmas week I was in a rush to get it installed and didn't want to wait for an answer. The directions do reference possibly needing to trim the plastic portion of the bed rail IF there was overhang, but I later found out I should have been sent longer brackets to clear the bed rail. Just a heads up if you encounter the same. You can see what I mean in the photo with the Pelican case from above.
The SE cover only comes with 4 anchor cleats at the 4 corners. I added 8 more so it had the same # of anchor points as the HD cover on my F150 raptor. Also added their light and toolbar on the rear panel.
Also installed the Pelican BX255 Case for more storage since limited inside the Cab. I ordered the XBEDMT-002-BLK bed mounts, but these do not work for the ranger bed. The bed appears to be too narrow for the length of these brackets. Rather than returning, I ended up modifying the Case to mount the bracket lower on the case to make it work. Also had to drill into the bed rails (just the plastic portion) and use the Tacoma adaptors vs the Universal ones. Not ideal, but was able to make it work. Just a heads up if looking to do something similar.
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed DB
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed DB1
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed DB2
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed DB3
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed DB4
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed DB5
Dracena
AZ
Had one of these on my 2G Tacoma for years. Great cover. Would you mind taking a slightly more elevated pic from the upper/rear? Something about the way the rear corners overhang, and no coverage over the tailgate has me divided on the RR fit.
FullSend
FullSend
Ninjaneer
The front of the cover is flush with the outer edge of the bulkhead weather strip that you have to add. Might be about to shift it back a half inch.
I'd say there is about a 1.5" of overhang on the tailgate.
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed 1000001922
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed 1000001925
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed 1000001926
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed 1000001927
Old Dawg G
Greg
Phoenix, Arizona
2024 Ford Ranger XLT
Thanks for sharing the details as well as the pics. It's looks really good. I just recently purchased a 2024 XLT with the FX4 package. I can't wait to start modding it up soon and covers like this are definitely something I'm interested in.
Hawkpilot10
Maine
Ranger Raptor 2024, Bronco 2021 Bronco two door Wildtrak
Retired Helicopter Pilot
I was hardcore Diamond Back on all my past trucks but this time I wanted a change. I recommend both products but this allows almost full access to the back. It’s all good! 🇺🇸👍🇺🇸
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed IMG_3356
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed IMG_3355
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed IMG_3354
Ford Ranger Diamondback SE Tonneau + Yakima Skyline HD system Installed IMG_3353
FullSend
FullSend
Ninjaneer
That's a very clean looking cover, I like it! I had a truck covers usa retractable cover on my Gen2 and loved it. Opted to try out the DB this time so I could stack extra gear on top and strap down.
2Barph
East TN
2022 BD Bronco
Looks great! Do you have the updated bed brackets to support the weight? Or do you think it'll be ok without the brackets? Thank you!
Hawkpilot10
Maine
No brackets needed. Does my RR already have the supports installed at factory? I think it does.
FullSend
FullSend
Ninjaneer
I bought mine before mid September so I did get the J Braces and had them installed. You would want the bed reinforced to support the weight of the cover and anything you plan to put on it.
Scotchaholic
NoVA
Do you have the Electric kit? If yes, do you have to use the app or provided FOB to open/close or is there integration with the OEM FOB like on the Retrax EQ?
