cfm56doc
- Thread starter
- #1
Got my Diode Dynamics 4 pin hitch mount LED reverse light and the wiring harness that came with the light will not fit thru the back side of the factory mounted receiver that came on my 24 Ranger Raptor. Assume same for all other trims with a factory installed receiver. In a nut shell, DD shows the backside of the receiver open just like the front, but the Ford receiver has a plate blocking off the front side with like a 1/2" hole and the connector is larger than the hole diameter. Not sure if I ordered a wrong light kit, a wrong one was sent, or it just will not work with a factory receiver?
Only way I can see making it work is for me to cut the connector off the provided wiring harness, run the wires thru the 1/2" hole in the back of the receiver and then re-join the wiring harness to light connector. And then I am not sure how much room is left in there with the connector inside the receiver should you want to install a hitch and ball.
Also not way to install a lock so someone does not help themself to your light, unless you cut off the side tension clips and then I think a lock will pass thru, but still back to wiring not working unless you hack the connector off.
Will try to get pictures tomorrow
