Driveline vibration 2024 xlt fx4
embedded rock
Earth
One truck, two motorcycles
Ok, I suppose both could be used if needed.
I might have used washer(s) for my former Tacoma. A $15 magnet protector was handy too.
embedded rock
Earth
Wedge shims on the rear leafs and axle of that Tacoma had the most effect at eliminating the vibration that was around 25mph.
Skip74
New York
2024 Ford Ranger XLT FX4
I installed the shims it seems all of my issues are gone. Except that the dealer stripped out my weld nut that is part of the frame. So I had to double nut the bolt. Fortunately the tsb came with a longer bolt. The bolt was loose when I went to install the carrier shims. Yikes could have been bad. Looks like another trip to the dealer, or I will just get a longer bolt.
embedded rock
Earth
That's stripped nut and not mentioning it or repairing is a bad deal. Sounds like you are able to do a good repair and avoid another trip to the dealer. Still, it seems they should know about it, but at this point they would most likely deflect responsibility--which could be why the let you install the shims given your Ranger is in warranty.
