Dumb question... how do you remove the bedrail caps?
ecoope
Vancouver
Ranger XLT FX4
biologist
Do they just pry out? I don't want to screw anything up...
TheRealSasquatch
Bronco
Ford Ranger Dumb question... how do you remove the bedrail caps? IMG_5304
Ford Ranger Dumb question... how do you remove the bedrail caps? IMG_5300
carefully lifting and using a small pick to push the clip teeth out of the latch position. Just prying will not work it stretches the plastic or they will break.
Ford Ranger Dumb question... how do you remove the bedrail caps? IMG_5236
BrrRaptor
Raleigh Nc.
No wonder I get so much dust in the bed. I installed a tailgate seal kit that helped a lot but riding out west for a week you get a light dusting all over your gear.
ecoope
ecoope
Vancouver
Ranger XLT FX4
biologist
I don't want to remove the entire assembly, just the 6 rectangular caps that tend to leak...
dart
Houston, TX
2025 Ford Ranger
There are tabs that face front and back.
I used a plastic pry tool to get up under the middle of the long side of the cap. You could also do it with a flat head screwdriver - just be careful not to scar the plastic.
If you zoom in on the photo, you’ll see the cover with the tabs.
Ford Ranger Dumb question... how do you remove the bedrail caps? IMG_5242
Ford Ranger Dumb question... how do you remove the bedrail caps? IMG_5241
PNW_Raptor
Jon
Washington
I simply used some black automotive sealant around those and it helps tremendously.
