Factory Key Code Location 2024 Ranger Raptor
Duran1filmz
Gabe
The Factory Key Code location to reset the door keypad is under the dash near the driver-side foot pedals. I used my phone to take a picture of it. It is hard to see physically but taking a pic with the flash worked for me.
Ford Ranger Factory Key Code Location 2024 Ranger Raptor 20250310_143403
BHunted1
Sumner County, TN
2024 Ford Raptor Ranger
Pull down Fusebox cover. the actual card is in a slot over the fuses. I keep mine in the house.
Daweism
Austin, TX
My least favorite add-on due to it being bolted to the door panel instead of integrated into the driver door side pillars.
T-Rev
Not "bolted" and can be moved. Many move it to the gas tank door so it's out of sight.
Daweism
Austin, TX
Oh? I had assumed there was drilled holes behind it.
wapta
Around
P703N Raptor
This code on the back of the bcm and the card over the fuses bcm the does not work, as there is no physical connection with the keypad to the bcm.
The card in the glove box that looks like this is the one for the wireless pad.
Ford Ranger Factory Key Code Location 2024 Ranger Raptor 1741672170824-c9
Salt_H2O
Salt_H2O
Northern VA
Note, for my RR, the factory code on the card (truck documentation in the glove compartment) was different than the code under the dash. The "card code" did not work, the under dash code did work to resent the keypad.
Tomikaze
Tom
Portland, Maine
24’ Cactus Gray Ranger Raptor
Automotive Software
Wait a second here... you're telling me this ugly wart is double sided taped to the door? It's a remote and nothing more??
Tomikaze
Tom
Portland, Maine
Automotive Software
Never considered looking it up. And knowing is half the battle.
