First Oil Change at 500 miles
Bill W
SoCal
2025 XLT Ranger 2.7
First, thank you for posting. I use the same UOA service, but am holding off testing for break in. I have 550 miles on my 2.7. Amsoil SS is a really good choice, I changed my oil to PUP. Seems there is a few obvious manufacturing leftovers in the first sample and nice to see the trend follow break in. Very informative info.
av8r
NY
This is why I prefer Blackstone or Caterpillar for oil analysis. They will tell you a lot more about the additive pack, make suggestions for maintenance intervals with hard numbers and warn you that sampling oil in a new engine is not useful data.
Yonder_MN
Yonder_MN
Joe
Minnesota
Thanks for the info!
I’ll have to check them out and maybe do a comparison next time. I have a couple of pre-paid analysis left to go.
- Joe
av8r
NY
- Joe
All data is good data, but some data is just more useful, in my experience.
Yonder_MN
Yonder_MN
Joe
Minnesota
Got the updated report, I think I was idling too much in my cold weather, will be making the next oil change a bit sooner to see if that helps
Got the free Blackstone kit and will run both on the next sample.
Bill W
SoCal
2025 XLT Ranger 2.7
First thought on the oxidation level had me worried on your last two samples. Seems Amsoil does run that same high level oxidation level on this test.
Yonder_MN
Yonder_MN
Joe
Minnesota
Yes, I did see that video and still learning what tests are what. Will keep with my approximate 5K miles changing schedule. Thanks for the reminder!
- Joe
Yonder_MN
Yonder_MN
Joe
Minnesota
I did a bit of digging and found the following using some AI prompts.
Gemini propmt - why does Amsoil signature series test with a high oxidation rate?
Thinking prompt -
Analyzing Oil Oxidation -
I've defined AMSOIL Signature Series' composition and what oxidation signifies in used oil analysis context.
Still validating what its says . . . .
Response:
It’s a classic "gotcha" in the world of used oil analysis (UOA). If you’ve just gotten a lab report back and the oxidation levels look alarmingly high for a premium oil like AMSOIL Signature Series, don't panic.
The high oxidation reading is usually not a sign of the oil failing; rather, it’s a byproduct of the oil’s high-end chemistry "confusing" the lab equipment.
1. The Role of Esters (Group V Base Oils)
AMSOIL Signature Series is a "super-synthetic." To achieve its high performance, it uses a blend of Polyalphaolefins (PAO) and Esters.
Esters are high-polarity base oils that provide excellent lubricity and detergent properties. However, from a chemical standpoint, esters contain carbonyl groups (a carbon atom double-bonded to an oxygen atom, represented as C=O).
2. How the Lab Tests for Oxidation
Most commercial labs use FTIR (Fourier-transform infrared spectroscopy) to measure oxidation.
  • The machine sends infrared light through the oil.
  • It specifically looks for the "stretch" or vibration of C=O bonds.
  • In standard petroleum or cheaper synthetic oils, C=O bonds only appear when the oil starts to break down (oxidize).
The Problem: Because AMSOIL Signature Series contains esters as a primary ingredient, the FTIR machine sees those C=O bonds right out of the bottle. The machine can’t distinguish between the "good" carbonyls that are part of the ester base oil and the "bad" carbonyls created by actual oxidation.
3. "Baseline" vs. Actual Degradation
If you test virgin (unused) AMSOIL Signature Series, it will often show a "starting" oxidation level that is significantly higher than a standard off-the-shelf mineral oil.
  • The False Positive: If a lab doesn't have the specific "virgin" version of that AMSOIL formulation in their database to use as a baseline, they will flag the result as "high oxidation."
  • The Trend is Key: When analyzing AMSOIL, you shouldn't look at the raw oxidation number in isolation. Instead, you look for the rate of change from the virgin oil sample. If the number stays relatively stable over thousands of miles, the oil is doing its job perfectly.
4. High Additive Loading
Signature Series also carries a very heavy additive package (high TBN, high levels of antioxidants). Sometimes these antioxidants—designed to prevent oxidation—can also slightly interfere with the infrared spectrum, contributing to a higher-than-expected initial reading.
What should you actually look for?
If you are worried about your oil actually breaking down, ignore the oxidation "flag" for a moment and check these three metrics instead:
MetricWhat it tells you
ViscosityIf the oil is truly oxidizing/oxidized, it will typically thicken significantly.
Total Base Number (TBN)This measures the remaining acid-neutralizing capability. If TBN is still healthy (above 1.0 or 2.0), the oil is likely fine.
NitrationThis measures breakdown caused by combustion byproducts. If nitration is low but oxidation is "high," it’s almost certainly the ester interference.
Bottom Line: You aren't seeing premature oil failure; you're seeing the chemical signature of high-quality synthetic esters. As long as your viscosity is stable and your wear metals are low, your engine is in great hands.
Then asked Gemini to compare the report against the data above:
Looking at the lab report for your Ford Ranger 2.7L, it is clear why the lab flagged the AMSOIL Signature Series 5W-30 with a "SIGNIFICANT" oxidation level.
The oxidation reading reached 51 abs/cm. To a standard lab algorithm, this looks like the oil is thickening and breaking down, but the data in the report suggests a different story.
1. The High Baseline Artifact
The most important number in this report is the Baseline (BL) Oxidation, which is listed at 33.
  • The "False" Jump: Most standard oils start with an oxidation baseline near zero. Because AMSOIL Signature Series uses high-quality esters, it has an "intrinsic" oxidation signature before it even enters the engine.
  • Actual Degradation: Your oil didn't "oxidize" by 51 points; it only increased by 18 points (51 minus the baseline of 33) over the course of the drain interval. For nearly 14,000 miles on the component, an 18-point rise is actually very stable.
2. TBN vs. Oxidation: The "Safety Net"
If the oil were truly oxidized to a "significant" degree, its ability to neutralize acid would be depleted.
  • Your Total Base Number (TBN) is still at 4.68.
  • Generally, oil is considered "spent" when the TBN drops below 1.0 or 2.0. At 4.68, your oil still has plenty of active additives to protect the engine, despite the lab's oxidation flag.
3. The Real Culprit: Fuel Dilution
The lab notes that the viscosity has decreased slightly below grade. While the analyst suggests this might be due to oxidation (which usually thickens oil), your data shows the opposite: the oil is thinning.
  • Fuel Dilution is at 3.1%, which the lab correctly identifies as MODERATE.
  • This fuel (gasoline) is acting as a solvent, thinning the 5W-30 oil down to a viscosity of 9.2 cSt.
  • The report notes this may be caused by "excessive idling" or the rings not being completely seated yet if the unit is relatively new.
Summary of Your Report
MetricResultMeaning
Oxidation (51)Flagged SignificantMostly a "false positive" due to the high-ester baseline of 33.
Nitration (13)NormalSince nitration is low, it confirms the "oxidation" isn't caused by heat or combustion distress.
Fuel Dilution (3.1%)ModerateThis is the actual cause of the viscosity drop, likely from short trips or idling.
Wear Metals (Iron 16)Low/StableDespite the flags, your engine wear (Iron, Copper, Lead) is trending downward or staying very low.
The Verdict: The AMSOIL is holding up chemically, but the fuel dilution is the metric to watch. If you do a lot of short-distance driving or idling in that 2.7L EcoBoost, that is likely why the fuel level is elevated.
So lots of data and I’ll continue to learn as I collect more!
- Joe
