Break in oil change before 9 hour trip? Currently at 1500 miles
surfstar
CA
2025 Lariat 2.3 FX4
I guess you didn't watch the video
I guess you don't understand the scientific method.
I don't see where he includes multiple engines for a control group and multiple engines for the test group.
Also if your oil analysis ppm are "high" - what does that mean? Does your engine self destruct? Does it use more oil? Does it make more/less HP? No, it means you post online about it and buy more expensive oil and/or change it more often. But why? To what end? Why not change every 100 miles?
Again, where is scientific studies showing that early oil changes make a lick of difference for passenger vehicles?
Bill W
SoCal
2025 XLT Ranger 2.7
Whether an oil lists GF-6 or GF-7 means they are certed to that spec. That does not mean that the oil formulation has necessarily changed.
btw, for those that depend solely on oil analysis numbers … do those numbers consider the build up of contaminants and wear inside the engine?
Ford spec. WSS-M2C961 is also WSS-M2C971 rated. (GF-6 and GF-7)
Personally consider the dual port and direct fuel injectors address the IVD issue. As far as the wear issue I do not know another way to follow the wear in an engine other than UOA.
BTW the intake valves use carbon on the intake valve seats as a sacrificial wear material. One of those balances that needs to be right for valve seat wear.
I get that, Valvoline didn't have to reformulate their GF-6 spec oils since they met the GF-7A criteria, weather Ford reformulated their oil or weather it already met that and simply went through the 7A testing to reach the cert is irrelevant and you or I won't know. But we do know that now, even if it didn't, it lists 7A, which was my only point is that it's to the latest spec.
AugPal
Augie
Chicago
Retired IBEW
The Certified Lubrication Specialist convinced me with the data he presented; you haven't.
surfstar
CA
2025 Lariat 2.3 FX4
That's the thing - there is no data. He has a sample size of 1. 1 engine. 1 "break-in" period. There is no control. The "data" is meaningless.
We have no idea what benefit multiple early oil changes actually do. "wear metals" go down - they do that if you follow the owner's manual / OLM oil change interval also. He does not present any data that proves early oil changes actually do good. But he sure got a lot of clicks on his video - that is proven.
