Ford Performance display live monitoring
TurboRanger
Jack
Oakley , Comifornia
Retired Truck Mechanic
On the Ford Performance tuner Has live monitoring of Oil psi /boost psi / coolant Temp and so on here is the Gauge description
CategoryGaugeDescriptionUnits/Meaning
SAEEngine LoadEngine load percentagePercentage (%)
SAECoolant TempCoolant temperatureCelsius/Fahrenheit
SAESTFT Bank 1Short-term fuel trim (Bank 1)Percentage (%)
SAELTFT Bank 1Long-term fuel trim (Bank 1)Percentage (%)
SAESTFT Bank 2Short-term fuel trim (Bank 2)Percentage (%)
SAELTFT Bank 2Long-term fuel trim (Bank 2)Percentage (%)
SAEMAP-SAEManifold Absolute Pressure (SAE)Kilopascals (kPa)
SAEBOOST-SAEBoost pressure (SAE)Pounds per Square Inch (psi)
SAERPM-SAERevolutions per minute (SAE)Revolutions Per Minute (RPM)
SAESpeedVehicle speedMiles per Hour (MPH)
SAETiming AdvIgnition timing advanceDegrees
SAEIATIntake air temperatureCelsius/Fahrenheit
SAETPS-SAEThrottle position (SAE)Percentage (%)
SAEFuel LevelFuel tank levelPercentage (%)
SAEBaro PressureBarometric pressureKilopascals (kPa)
SAEBatteryBattery voltageVoltage (V)
SAEAir TempAmbient air temperatureCelsius/Fahrenheit
SAEThrottle ActThrottle actuator positionDegrees
AIRFLOWBP HgBoost pressure in HgInches of Mercury (Hg)
AIRFLOWMAPManifold absolute pressureKilopascals (kPa)
AIRFLOWBOOSTBoost pressurePounds per Square Inch (psi)
AIRFLOWBOOST/VACBoost/Vacuum pressurePounds per Square Inch (psi)
AIRFLOWWastegate_DCWastegate duty cyclePercentage (%)
AIRFLOWBPBarometric pressureKilopascals (kPa)
FUELRear_02_Corr_B1Rear O2 correction (Bank 1)Correction factor (No Unit)
FUELRear_02_Corr_B2Rear O2 correction (Bank 2)Correction factor (No Unit)
FUEL02_Volts_B1S2O2 sensor voltage (Bank 1 Sensor 2)Voltage (V)
FUELAFR_MaturedAir-Fuel Ratio (Matured)Ratio
FUELClsd_Loop_FuelClosed loop fuel statusNo Unit
FUELDSP-LambdaDesired Lambda valueRatio
FUELAct_Lambda_B1Actual Lambda (Bank 1)Ratio
FUELAct_Lambda_B2Actual Lambda (Bank 2)Ratio
FUEL_TFT_B1Transmission fluid temperature (Bank 1)Celsius/Fahrenheit
FUELLTFT_B2Long-term fuel trim (Bank 2)Percentage (%)
FUELSTFT_B1Short-term fuel trim (Bank 1)Percentage (%)
FUELSTFT_B2Short-term fuel trim (Bank 2)Percentage (%)
FUELOpen_Loop_FuelOpen loop fuel statusNo Unit
FUELFRP_AbsoluteFuel rail pressure (absolute)Pounds per Square Inch (psi)
FUELFuel_LevelFuel tank levelPercentage (%)
MISCOil PressureEngine oil pressurePounds per Square Inch (psi)
MISCMIL_Light_is_OnCheck engine light statusOn/Off
MISCTorque_SourceEngine torque sourceIdentifier
MISCLOADEngine loadPercentage (%)
MISCRun_TimeRun time since startSeconds
MISCTire_FLFront left tire pressurePounds per Square Inch (psi)
MISCTire_FRFront right tire pressurePounds per Square Inch (psi)
MISCTire_RLRear left tire pressurePounds per Square Inch (psi)
MISCTire_RRRear right tire pressurePounds per Square Inch (psi)
RPM/SPEEDDSD_RPMDesired engine RPMRevolutions Per Minute (RPM)
RPM/SPEEDRPMEngine revolutions per minuteRevolutions Per Minute (RPM)
SPARKKnkSenl_CntsKnock sensor 1 countsCounts
SPARKKnkSen2_CntsKnock sensor 2 countsCounts
SPARKLind_Knk_ModLinear knock module valueValue
SPARKKnkAdderKnock sensor adderValue
SPARKOct_AdjustOctane adjustmentValue
SPARKSpark 2Spark advance for cylinder 2Degrees
SPARKSpark 3Spark advance for cylinder 3Degrees
TEMPCat_Temp-BLCatalyst temperature (Bank 1)Celsius/Fahrenheit
TEMPCat_Temp_B2Catalyst temperature (Bank 2)Celsius/Fahrenheit
TEMPACTAmbient charge temperatureCelsius/Fahrenheit
TEMPACT2Ambient charge temperature (sensor 2)Celsius/Fahrenheit
TEMPCHT_TempCylinder head temperatureCelsius/Fahrenheit
TEMPECT1Engine coolant temperature (sensor 1)Celsius/Fahrenheit
TEMPECT2Engine coolant temperature (sensor 2)Celsius/Fahrenheit
THROTTLEAct_Thrt_AngActual throttle angleDegrees
THROTTLEDsrd_Thrt_AngDesired throttle angleDegrees
THROTTLEPedal_PosAccelerator pedal positionPercentage (%)
THROTTLERel_Pedal_PosRelative pedal positionPercentage (%)
THROTTLETPSThrottle position sensorPercentage (%)
TRANSSpd_RatioTransmission speed ratioRatio
TRANSNeu-Dr_StatusNeutral/Drive statusOn/Off
TRANSDSD_Conv-StipConverter slip (desired)Revolutions Per Minute (RPM)
TRANSSlip_Across_ConvSlip across converterRevolutions Per Minute (RPM)
TRANSConv_CurrentConverter currentAmperes (A)
TRANSOvrshoot_RPMOvershoot RPM during shiftRevolutions Per Minute (RPM)
TRANSShift_Flare_RPMShift flare RPMRevolutions Per Minute (RPM)
TRANSShift_sis_TimeShift timeMilliseconds (ms)
TRANSCur_Trans_RatioCurrent transmission ratioRatio
TRANSGear_CommandedGear commanded by ECUIdentifier
TRANSShift_IDShift identificationIdentifier
TRANSTap_DownTap downshiftRequest
TRANSTap_UpTap upshiftRequest
TRANSTrans TempTransmission fluid temperatureCelsius/Fahrenheit
VCTDs_ExhCam_PosExhaust camshaft position (desired)Degrees
VCTDs_IntCam_PosIntake camshaft position (desired)Degrees
VCTExCam_Pos_B1Exhaust camshaft position (Bank 1)Degrees
VCTExhCam_Ang-B2Exhaust camshaft angle (Bank 2)Degrees
VCTExhCam_DC_B1Exhaust camshaft duty cycle (Bank 1)Percentage (%)
VCTExhCam_Err_B1Exhaust camshaft error (Bank 1)Degrees
VCTExhCam_Err_B2Exhaust camshaft error (Bank 2)Degrees
VCTIntCam-Ang_B2Intake camshaft angle (Bank 2)Degrees
VCTIntCam_DC_BlIntake camshaft duty cycle (Bank 1)Percentage (%)
VCTIntCam_DC_B2Intake camshaft duty cycle (Bank 2)Percentage (%)
VCTIntCam_Err-BlIntake camshaft error (Bank 1)Degrees
VCTIntCam_Err_B2Intake camshaft error (Bank 2)Degrees
RRaptorscallion0331
Colin
Do you have yours mounted and if so, how/where? Also, is it permanently taking up the OBDII port? (I have a banks pedal monster I’m thinking of reinstalling since the truck was FP tuned.
TurboRanger
TurboRanger
Jack
Oakley , Comifornia
It does not need to be plugged in all the time .
Load it and unplug and put it in a safe place. Your stock tune is saved in it.
RRaptorscallion0331
Colin
Yea sorry, I meant if you want the live monitoring, where would you mount it and how.?
TurboRanger
TurboRanger
Jack
Oakley , Comifornia
RRaptorscallion0331
Colin
thank you for the info, I was hoping for something a little more sturdy than a suction cup, which I don’t remember seeing in the procal tune box… but that’s a good idea about the splitter. Thanks again!
At a glance that looks a lot like what I have exposed through my scan gauge 3, and I’m guessing anything else that uses the obd port. I think a lot of it is exposed on the standard OBDLINK companion app for OBDLINK mx+ (and their non-Bluetooth siblings). It’s sad. It I’ve resorted to using either of these just to expose my battery voltage since I can’t do that on either the dashboard the center screen.
TurboRanger
TurboRanger
Jack
Oakley , Comifornia
Ford Ranger Ford Performance display live monitoring 20260916_112948
Sportshot2
Jerry
2019 F 150 FX4 (totaled) 2021 Acura RDX, 2021 KIA
I just got the tune installed about a week ago. The dealer mounted it on the lower left corner of the windshield. I didn't like it being there so I just unplugged it and left the wiring plugged into the port. I can't think of any reason I would want to mess with it while the truck is running. I'm 78 and see no need to be distracted by the tuner when I'm happy with how it runs
Regarding the tune, I love it after just one week. Really sorry I didn't do it sooner. I
TurboRanger
TurboRanger
Jack
Oakley , Comifornia
I don't have mine plugged in and on the windshield If some thief steals it they will have my stock tune also
Mine is also in the house. The dealer mounted it on the lower left of the windshield but I didnt want people seeing it and thinking it's something to steal
