Sequoia
Dan
Germany
Ranger Wildtrak 2023
Still no idea how to open and close the e-shutter while driving? It only works when in P… 😕 Several times I drove off and forgot to close the shutter.
Hande
Hannu
Estonia
Business Owner
this is how I turned off the start stop on my Raptor 2023
Disable Auto Start-StopBdyCM726-48-02x*xx-xxxx-xxxx*=0
BMS ConfigurationBdyCMNON-ASBUILTBMS ConfigurationPWM
Auto Stop StartIPCNON-ASBUILTAuto Stop StartDisable
Battery Target State of Charge, %BdyCMNON-ASBUILTBattery Target State of Charge, %100%
What are these different BMS configurations? There seems to be "none", "LIN" and "PWM" 🧐
EzequielArgentina
Ezequiel
Buenos Aires, Argentina
Ford Ranger T9 2024
Auditor
I changed those parameters, and it looks like ASS is not longer working (so, the solution worked). I did it this morning, and during today's commuting, the ASS was not activated. I will keep my fingers crossed.
keep track so someone can update the spreadsheet for future reference
YukonRanger
Yukon
Is there a way to make the adaptive cruise control automatically use the current speed limit as the target speed when engaged?
Always the first time you turn it on the truck locks at your current speed and you have to manually use the rocker switch to get up to the speed limit...not a big deal but it seems to me a no brainer when you have speed sign recognition enabled it should initially target that speed.
does other manufacturer's cruise system do that? thats super cool if they do.
i have a mazda3 with the sign recognition (i guess it has it, the speed limit signs show up on the screen) but i still have to adjust my cruise like you are saying, with the buttons on the steering wheel
Hande
Hannu
Estonia
Business Owner
EU Ranger Raptor has that feature, so there must be a way to make it work.
You can switch it on/off in Sync in EU RR.
EzequielArgentina
Ezequiel
Ford Ranger T9 2024
Auditor
Sorry for the spam.. but I can NOW confirm that it worked!... no ASS in my truck. The indicator is still shown in the IPC (because I did not remove it), but it is never "green".. so it shows ASS is on standby, but it gets never "activated"... So. that is great.
I have also configured the turn lights to keep on as DRL following the instructions shared here, and it worked as well.
Hande
Hannu
Estonia
Business Owner
I am trying to enable staying in same drive mode after engine restart.
IPC has " Selectable Drive Mode" what does it do, any experience?
I tried to do that also. Even turning off normal, it still started in normal mode.
Hande
Hannu
Estonia
Business Owner
Same where, no ASS for 3 days so far :)
BMS Configuration PWM
Battery SOC 100%
Still, it does not charge more than about 85%-86%, even during long drive 🧐 Just current gets down to 2-3A.
Any idea, why it does not get better than that, even SOC is set to 100% ?
radial
Rich
Maryland
Any idea if this would work on my 2024 RR?
Hande
Hannu
Estonia
Business Owner
Works well for me, 2024 EU RR
Could it be, that EU and NA are so different?
