Sequoia
Dan
Germany
Ranger Wildtrak 2023
But how are they supposed to help there? The Bronco has it as standard. And the picture above is from a friend of mine who somehow managed to get at least the symbol onto the Ranger.
Sequoia
Dan
Germany
But the picture was taken by a friend in his car; it’s from his Ranger Wildtrak. He changed some settings in Forscan and discovered a few days later that this symbol appeared.
Sequoia
Dan
Germany
Now I’ve figured out how to get the button into the display. You need to activate this in the APIM.
Unfortunately, the button doesn’t function, which makes me assume that something else needs to be activated somewhere.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_3204
lifeline
Chicago
Anyone get mirror tilt when in reverse to function? I activated it and see it on the tablet menu but it is non functional. There must be another setting required. Same thing with walk away lock, it’s in the menu but doesn’t function.
Sequoia
Dan
Germany
Tilt on reverse needs memory seat Funktion.
lifeline
Chicago
you mean I need to activate it somewhere in Forscan or I need to have memory seats? I have an NA Ranger Raptor so I have functioning memory seats
Sequoia
Dan
Germany
You need memory seats.
than you can activate it in 2 modules. But not in my mind which one. But in 2 different
lifeline
Chicago
I found the two modules in which to activate but the mirrors won't dip.....sad.
Has anyone gotten the truck to auto lock upon walking away?
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
Next question: The Bronco has a tire camera. A friend of mine suddenly had the icon appear on his Wildtrak after making some changes in FORScan (he doesn’t remember exactly what he changed). However, when he presses the button, nothing happens. Does anyone know how to activate the camera (it’s taken from the ultra-wide-angle lenses on the mirrors)?
How about removing those stupid white lines that stop you from actually seeing what is in front of you when on the trail?
Sequoia
Dan
Germany
@CrustyNoodle That’s not the point at all. It’s about an additional camera angle that is available on the Bronco. The icon can also be unlocked on the Ranger, but it doesn’t work. The Bronco also just uses the cameras in the mirrors to generate the images for the tires. I was hoping to find knowledgeable people here who have specifically dealt with this using Forscan.
DIYPSCM
SF Bay area
2024 Ranger 2.7 Lariat
On my '24 Lariat, pressing the + button on the shifter will bring up the 1-10 gear display under the Tach. Any way to make that mode the default on startup?
Sequoia
Dan
Germany
Is not possible without a separate box installed.
vangev
Vlado
Melbourne
2024 Ranger Platinum, 2022 Ranger Wildtrak
I'll look at my setting tonight.
I'll go over my settings tonight. Tyre psi and temperature are pretty cool too.
I'm wondering about the gears showing on the dash, is this showing permanent or just when you press the - (minus) button on the gearshift knob? Can I change/activate this on forscan as the default per the photo?
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 20241017_161559
