Raptortugal
Portugal
Ranger Raptor 6g
This allows you to change the fuel display from 0/1 to E/F (empty/full).
I changed it in the easy "non as built" menu.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_20250312_142237
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_20250312_141909
HyperM3
Lawrenceville, NJ
The left gauge showing 60 & 120 as min & max temp (this is Numeric) and the middle gauge showing C & H (this is the Alphabet)
OK, so I enabled the numbers on my engine temp and oil temp? Maybe transmission temp too. But are you doing alphabet for some and numberic for others? Also, I need to check this, but I dont think I ever saw a red line on my gauges. Maybe I need to look at my dash more often lol.
wawy
Wawy
Saudi Arabia
The above photo was taken after I enabled the digital gauge option and before using the minor gauge unites which make the three gauges identical as shown in below picture.
No Idea about the redline (my car made in Thai which may differ from the NA)
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Screenshot 2025-03-13 232922
HyperM3
Lawrenceville, NJ
No Idea about the redline (my car made in Thai)
OK, when I get out to my truck after work, Ill take a picture of what mine looks like to compare and see what I can change.
HyperM3
Lawrenceville, NJ
Forgot to post. Here's what my gauges look like.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet PXL_20250313_230338148
Sequoia
Dan
Germany
Ranger Wildtrak 2023
I'm dealing with a new puppy and don't have time to test but you can try:
BCM 726-38-01
xxxx-**xx-xxxx
Your as-built here should say 0A, which is hexadecimal for 10.
You should try 64, which is hexadecimal for 100.
You can try any value between 0-100 just run it through a converter like the one below:
https://www.rapidtables.com/convert/number/decimal-to-hex.html?x=100
I tried it and it works! But after setting HEX 32 (for 50) it will not dim any more when turn signal is on.
After resetting back to 0A the dim while turn signal works again.
Waffel
Orlando, FL
They don’t dim with the headlights on using the turn signal, or with the headlights off using the turn signal? If the headlights are on you probably can’t expect the DRL to dim with the signals.
Sequoia
Dan
Germany
Both. Tried it both way. Headlight off and on.. They do not dim any more.
Ragner
Victoria
2022 ranger XLT
Supervisor
Probably more correct:
IPMA 706-02-02 xxx9 xFx xx--
APIM 7D0-01-04 xxxx CDxx xx--
We do not have a CHMSL (Center High-Mounted Stop Lamp) or Aux camera. Our cameras are in the notes as "reverse" and "hitch" only.
Does your 50/50 work at speed? Just wondering if any of these codes will enable..
