scoob8000
pa
2025 rang5stx
Just got a 2025 Ranger and made a few tweaks with Forscan 2.6.65 with success. Blinker flashes, boost gauge, seatbelt OK warning, etc. Successfully wrote to Bdycm, IPC, and SCCM. I just went to fix the power port timeout from 1s to 7200s. But it fails to write. Looking at the log, it stops at block 57 which is the power port.
On a whim, I tried making another simple change in BdyCM but not messing with the power port. Same thing, soon as we get to block 57, service procedure interrupted.
I looked at editing the power port in the as built mode, but seems to give me an invalid checksum whenever I change it.
Not sure what happened or how to fix.
TurboDog
Rod
West Melbourne, FL
2010 Raptor (Gen 1), 2025 Ranger Raptor
I just downloaded ForScan and the new 9.3.66 version is available. Beta testers have reported it corrects this issue, so maybe update to the newest version and see if it works.
scoob8000
pa
2025 rang5stx
Will give it a shot tonight! Thanks!
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
In forscan I see theres options for a CHMSL bed cam, has anyone successfully added a camera either in the 3rd brake, or front and got it to function properly with forscan? looking at putting in a 17-20 Raptor 3rd brake, but if I can add the 21- current with camera if not much more.
Aircraft examiner
The spreadsheet is the same, its for the truck.
antonioricardoz
Antonio
Brasil
Ranger XLT 24/25
Empresario
Alguém sabe como desligar completamente os faróis e as DRL em uma Ranger XLT 2024?
Mesmo com o interruptor de luz na posição 0, as luzes permanecem acesas. Quero que tudo fique completamente apagado. Existe alguma maneira de fazer isso com o FORScan?
Francoocnarf
Franco
Argentina
Ranger xlt 2.0 bit
Ing
Hola a todos, escribo en español porque es más que nada un mensaje para los dueños de Ranger fábricas en Argentina. Pude activar modos de conducción, eco coach, la pantalla all- terrain y un par de cosas más en mi Ranger xlt 2025 4x4, pero no logro activar el tta (trail turn assist). Love poner en la pantalla el botón pero no hace nada. En la memoria 760-01-03 tengo solo 4+2 dígitos es decir 16 bits ( más los ocho bits de verificación), al igual que algunas f150. Intenté activar uno por uno los bits desactivados pero sin exito para el tta. Alguna idea? Tal vez es otra posición de memoria? Tal vez desactivando otro?
Otra cosa que no puedo hacer es activar el bloqueo de diferencial desde la pantalla all- terrain ni la asistencia de descenso, desde las teclas funcionan bien. Me gustaría que alguno que tenga una limited 2.0 me mande un bkp de dos módulos apim y abs para comparar, porque entiendo que está versión si tiene la pantalla all terrain y la posibilidad de activar el bloque y asistencia por el touch screen.
Hay algún forro como este para las Ranger de Pacheco?
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Does anyone know a way to program the electric blind so that it also works when the vehicle is not in the ‘Park’ position?
Sequoia
Dan
Germany
I got the Signature Lux amber LED's installed to change my DRL's to amber. (Looks amazing especially with the 3 amber marker lights I added) Wondering if there is a way in Forscan I can disable the front turn signals and use the DRLs as the turn signals.
What kind of marker lights do you purchased??
Sequoia
Dan
Germany
Can someone quickly remind me how to set it so that both the bed outlet and the interior outlets keep supplying power for about 10 minutes after shutting off the engine?
Can't answer your question but I can say I have this disabled on my Tesla, much more important to see what I'm about to back into/over. I actually found the feature kinda annoying.
On my cars with reverse tilt how it behaves depends on which mirror is selected for adjustment; if I select the right mirror, then the right mirror tilts when I reverse, and if I select the left mirror then the right mirror does not tilt in reverse. This makes it simple to use for parallel parking on the right side (tilt is valuable) or higher speed reverse in my straight driveway where I don't want it to tilt. Having to enable or disable the feature like it sounds in your tesla, seems to be a poor implementation of a feature that is at times rather useful.
