24AzureGrayFX4
- First Name
- Gabriel
- Joined
- Nov 12, 2024
- Threads
- 2
- Messages
- 7
- Reaction score
- 0
- Location
- Glendale, AZ
- Vehicle(s)
- 2024 Ford Ranger XLT
- Thread starter
- #1
Wondering if anyone has wired up an ARB twin compressor or knows a thing or two about wiring/electrical in these new rangers. I just purchased an ARB twin compressor and plan to mount it under the hood in my 24 XLT and running power to the trucks battery. Im not concerned about running power from the compressor to the battery but I am scratching my head trying to determine how to wire in the on/off switch. I plan on using the switch that comes in the ARB kit as an on/off switch for the compressor and looking at the ARB wiring diagram, i believe switches 1 & 2 are for front and rear lockers which i wont be using. So I would be using the isolation switch wiring setup. But then it says red-yellow wire goes to ignition and blue-white to dash illumination and this is where I get confused. Where exactly do those go to in the truck? And do I need to run those wires or can i just run power and ground to the switch? Thank you for the help, electrical is certainly not my strong suit.
