Hood Rattle/Vibration
CodyMac
Cody
Rockwall, TX
Data Analyst
I figured I couldn't be the only one experiencing this, but I searched here and found nothing. At interstate speeds, sometimes my hood vibrates to the point I'm wondering if it's latched. I looked and the two rubber "stops" are adjustable, so I turned each one counter-clockwise about 1.5 turns and it's a much tighter fit, now. I haven't tested it out on the highway, yet, but will report back once I do (later this week).
VehicleNanny
Bill
vehiclenanny.com
Retired from General Motors
Ford issued a service bulletin to address hoods that are hard to close or set the hood ajar warning. While not specifically your issue, the service procedure does describe how to adjust the hood for proper closure. Hope this helps!
1. Open the hood.
2. Adjust the bump stop rubbers located on the hood assembly by turning the bump stop rubbers clockwise until the bump stop rubber is fully wound in to the hood inner panel.
3. Once the bump stop rubbers are wound in all the way, turn the bump stop rubbers counter clockwise 3.25 turns.
4. Open the hood and hold it 12-13 inches (304-330 mm) above the latch and drop the hood. Did the hood latch easily?
(1). Yes - repair is complete.
(2). No - proceed to Step 5.
5. Remove the radiator sight shield. Refer to WSM, Section 501-14.
6. Loosen the latch attachment bolts (Figure 3) and align the latch so it is centered to the hood striker.
7. Open the hood and hold it 12-13 inches (304-330 mm) above the latch and drop the hood. Did the hood latch easily?
(2). No - proceed to Step 8.
8. Adjust the bump stop rubbers located on the hood assembly counter-clockwise 0.5 turns.
9. After adjustments are made, closely inspect for even panel gaps between the hood, fenders, and grille and align as necessary. Refer to WSM, Section 501-03.
10. Reassemble the vehicle.
Black Shadow
William
Richmond Va
2025 Ford Ranger XLT
CDL trainer
You drop $50-60k for a mid sized truck and nothing but issues, recalls and sloppy workmanship. How I remember why I took a break from Ford for so many years
VehicleNanny
Bill
vehiclenanny.com
10. “Reassemble vehicle”. Reminiscent of old Haynes Manual steps:
1. Remove negative battery cable.
2. Remove rear axle from vehicle.
reinstall process is reverse of removal.
:like::like:
I chuckled over Step 10, too. It made it sound like much more work was performed in steps 1-9.
MasterCylinder
Jay
Retired, FF, CET, Mechanic
My XLT was not adjusted properly from the get go. The latch was set too high. How to check, adjust bump stops until the hood height matches the fender height on both sides near the stops. Close hood, then push down in the center if you can feel and hear it hit in the latch it needs adjusting down. Mine was almost a 1/8 of an inch off. Mark latch position with a pencil to see how much your adjusting. If I remember it's an 8mm wrench on the bolts. I sure wasn't going to sit a dealers for hours when it took all of maybe 15 minutes to do myself. Test as previously posted by VehicleNanny, step 4! Step 10 is crucial though! :like:
sweeks888
Richland, WA
Another fix would be to install under hood struts like these (my personal choice off Amazon, after trying 2 other cheaper ones). They keep slight constant tension on the hood, which in theory should prevent any rattle I would think. Just a thought...
https://www.amazon.com/Redline-Tuni...ix=hood+struts+for+2025+ranger,aps,213&sr=8-4
MasterCylinder
Jay
Not trying to belittle your thoughts but a hood strut, shock whatever people want to call them, should have zero effect of lift and no pull down (near closed) effect if brackets, shock length, and proper geometry is maintained. Otherwise it's not of correct geometrical design, shock rated power, for the intended purpose of a hood lift support. It should be in a neutral position within about 6-10 inches of closed or open and actually hold itself there in that neutral position. Then lifting further they should lift and hold the hood on there own without a jarring effect. :)
JrHDRanger
Indiana
My fenders were so low, when I brought the hood up to the point it wouldn’t move with the wind the hood to fender levelness looked like crap. I ended up having to shim up 3mm under the front top fender bolt and 2mm up under the second bolt both fenders. Now hood is adjusted up tight and hood to fender levelness is even, the hood seals on the fenders are nice and tight also which helps. It’s been rock solid since except last week when I was doing 80 with a 50 mph side wind.
sweeks888
Richland, WA
Possibly... But I can tell you These struts from Redline have a fair amount of resistance all the way to closure. So thought might do the trick... perhaps not.
CodyMac
CodyMac
Cody
Rockwall, TX
Data Analyst
Okay, I tested it. It's not a latch adjustment or anything like that. It's just the two rubber stops. It is 100% resolved. It used to vibrate bad going 75 to 85 down the highway, now it is Rock solid. One and a half turns counterclockwise on each of them.
DirtDerrick
Nathan
Atlanta
dirtderrick.com
People Person
You already fixed it, but I read all this so I was gonna say, adjust them until it doesn't move. I play with mine until the hood doesn't move at whatever speed.
