The Lone Ranger
Great information - thanks very much. My blend date is 0607 - so assume from what you said it should be built by now even though it still shows "in production" ? The modules have 3 columns for each entry - some have two blanks and some have one blank - does that mean until you have all three columns filled they are still working on the truck ?No, but if you look at the top of your sticker you will see the word blend with a number. In my case the blend was, 320240409. Ignoring the first number, you can see the date of 2024.04.09 (YYYY.MM.DD). That is the date your truck body and frame were or will be built and also all your modules will become active. So, if you have a blend date of say 2024.06.20 then your truck will be built tomorrow. Could slip a day or so depending on Production line issues.
This link will show all the modules associated to your truck. Once you see them that will indicate your truck has been built. Really nothing more about it except more confirmation that your truck has moved out of the being-built phase.
Index - FordServiceInfo.Com (motorcraftservice.com)
But the 'In Production' status is kind of general and it appears to include QA. So, depending on whatever QA finds, your truck could sit for days, weeks, months. Many on this forum have given up on their trucks that sat for months and found a truck pretty close to one they ordered as far back as May of last year.
The 'In Production' status is the black hole of statuses because it goes in and can sit without any explanation from Ford as to why your truck is sitting there. Most everyone here agrees that the wait would be less painful if Ford would explain what the delay is.
The Pre and Post 'In Production' statuses are fairly straight forward and things tend to move routinely. Usually, but no guarantees. I see you are in Oregon and so most likely your window sticker shows rail at the bottom left. It could take a while to get it from MAP to your dealer, but you can track it. There are rail codes that correspond to the one on your window sticker. Search these threads to find the rail code spreadsheet if you want to go down the proverbial rabbit hole.
But maybe you will be one of the lucky ones and get your truck in a timely manner. Whatever that is to you.
Good luck.
