How to fill RR gas from gas can.
BrrRaptor
Raleigh Nc.
So when I stick gas can nozzle in RR it won't open then inner flap. When I stick fuel pump nozzle no problem.
How do you put can in if on trail with gas can?
GManGeno
'24 Ranger Raptor
DevOps Engineer
Yes, there are two clips on the left and right of the fule tube, and to open the actual fuel 'door' inside, those two clips must be pressed to the side for the 'door' to be released. Basically, you need a tube of the correct diameter like the gas station filler or the funnel behind the seat.
Deleted member 9086
You can pick those up at most parts stores; AutoZone, O‘Reilys, Napa etc.???
Johnny 5
John C
Mold maker
You have to use the white funnel that is behind the back seat by the jack.
I was wondering where they kept it in the Ranger. Thank you! I use it for jet fuel (STP Octane Boost)!!!
Full-size no more
2020 1500 AT4-gone
Just my two cents, a safety siphon will put fuel in just as fast without you holding a Gerry can that could potentially spill or scratch paint. Also available just about anywhere.
