how to turn off the daytime running lights on Next Generation Ranger Wildtrak
HDL
Queensland
Ford Ranger Wildtrak
Hi everyone,
Is there a setting of how to turn off the daytime running lights ? on Next Generation Ranger Wildtrak 2023
Regards,
HDL
mehmetmsm
Mehmet
Antalya
Next-Gen Wildtrak 2.0
Hi,
I assume function for DRL control is not available as default because I've also don't have the function for DRLs on my Wildtrak. I think first you need to enable the setting for DRL control via Forscan either at APIM module for SYNC or at IPC module for Cluster. Then you can control the DRLs.
You may have look at this spreadsheet which was shared in this forum by @jezzza :
Memo
jezzza
Jezza
Brisbane, AU
2022 Ranger Raptor
‎‎ Engineer
Did you work it out? The option to enable/disable DRL should be added to your settings menu.
mehmetmsm
Mehmet
Antalya
I didn't add DRL option yet but I tried other options like enabling drive modes, approach detection etc. and they worked.
May be it is not related to this topic but currently I focused on trying to fix an issue with connected vehicle features which are not visible on my SYNC Connectivity tab(due to regional limitations I guess) even the modem is visible on SYNC. So far I played with APIM and TCU asBuilts but it i didn't help. I concluded that I need to change some values on GWM to enable missing options on SYNC but I couldn't find any spreadsheet for GWM so far.
thx.
Lanz D
Lanz
Philippines
2022 new gen ranger wildtrak 4x4
grab driverr
BCM
726-21-01
xxxx xxxx x1xx
this is a much simpler method. DRL turns off if headlamp switch is turned to "0" and turns back on if its in AUTO mode.
