insulating upr catch can from excessive heat
joecounty2025
joe
texas
2024 ford ranger xl stx 4x4
how many of you guy do this?
To insulate an UPR catch can for summer temperatures, consider using a catch can heat shield to prevent engine heat from directly warming the catch can. Alternatively, foam pipe insulation, similar to what's used for pipes in homes, can also help reduce condensation buildup by insulating the catch can and hoses
from what i understand if the catch can is hot it wont trap the moisture?
TheRealSasquatch
Bronco
Moisture isn’t any more harmful than driving on a humid day. Yes It technically doesn’t help with power because it lowers air density but that’s another conversation. Insulating those pipes in a hot engine bay will only slow energy transfer until the pipes reach the ambient temp of the engine bay. All bets are off it those pipes are in close proximity to the exhaust or your daily commute is only like 2 miles.
Water collected in the catch can is only an issue if it freezes and splits the can in the winter.
For my catch can I haven’t worried about insulating the pipes. If I was running a race team and was looking for F1 performance maybe a few engineers would be seeing if there was any gains in this area.
Deleted member 9086
Condensation isn't the enemy, but a combination of; condensation, oil and fuel vapor is. Under pressure and high heat carbon forms. I’ve run water injector kits on several engines and it actually keeps the engine much cleaner and provides better combustion performance.
CCā€˜s in general will capture; condensation, oil and fuel. I run a single port UPR CC and your find in its present mounting location, there are all three present.
As noted above from ; @RealSasquarch?
Water collected in the catch can is only an issue if it freezes and splits a chance can in the winter.
Additionally, you don’t want condensation freezing in the lines. So, you want to keep the CC in a higher heat location for this issue and purpose.??
joecounty2025
joecounty2025
joe
texas
I emailed upr, this is there response
Ford Ranger insulating upr catch can from excessive heat IMG_9808
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
I’ve never insulated mine. And i ran my mustangs hard. Always collected a good bit too.
Maybe
Brock
CA
Deleted member 9086
yea. Never ever heard of insulating a catch can until i saw it on this forum!
Neither have I. Never insulated one on several automobiles.
UPR may tell you to insulate to stop it freezing overnight in zero temps but as long as the CC is emptied regularly, there’s not an issue with one that is partially filled.
Soon as the engine warms up the condensation unfreezes. As long as fluid level is not equal to the inlet or outlet hoses, there’s no issue.
If the CC hasn’t been emptied for quite sometime and is full, then it will cause a blockage of the crankcase ventilation system.
Northern tier states with sub zero temps, I’d personally remove it during the winter months.??
