Most Popular FORSCAN Changes
HyperM3
Lawrenceville, NJ
I got the OBDLink EX, seems to work fine. I had an older one laying around that didn't work, so cable makes a differece.
Yeah I just ordered that cable. Was using a Bluetooth obd link, I'll see if that was the issue.
Ag3ntC00p3r
Product Manager
I could be wrong but BLE dongles are only supported by viewing and clear code apps like FORScan Lite and OBDFusion. Windows app needs hardwired OBD to USB cable.
Ford Ranger Most Popular FORSCAN Changes IMG_0168
HyperM3
Lawrenceville, NJ
I already used my Bluetooth dongle to make some changes. But I will see if the cable connection gives me access to more modules. I should have the new one tomorrow.
derichio02
Bo
Southern California
Bronco Raptor, Maverick Hybrid, Ranger Raptor
I have set my fogs to be on with high beams and I turned off the DRL wink when the turn signal is on.
Im also playing around with proximity unlock when you walk up to the truck.
Where is the drl wink instructions.
HyperM3
Lawrenceville, NJ
Pampa
Argentina
Ranger v6 LTD+
Agro
No puedo hacer que escriba el módulo IPC. He escrito otros (BdyCM principalmente), pero ese siempre arroja un error de "servicio interrumpido". Probé la última versión anoche. Sigue apareciendo el mismo error.
[/CITA]
yo tengo el nuevo conector OBD II, y el mismo problema, no me aparece el modulo IPC, todo el resto aparece menos ese modulo. Tambien probe de todas las maneras y no puedo...
HyperM3
Lawrenceville, NJ
Oh I will check that out! I found another option that was "DRL with Turn Signal" that was disabled. I turned that one on but havent tried it out yet.
Yeah I think there are a couple in there like that. I switched them all to enabled. If I have time I'll go one by one and see which is the actual one that does it.
derichio02
Bo
Southern California
I just checked and confirm that “DRL with Turn Signal” works!
HyperM3
Lawrenceville, NJ
Yeah that's the one I was looking for. Should be in the same module. Thanks for sharing!
HyperM3
Lawrenceville, NJ
OK, I got the new cable yesterday. Not only did I discover that my license key expired but I was not able to see the other modules without creating a new file(instead of picking the saved file I had used prior to get into the modules). After all the updating I was able to get into all the modules with the Bluetooth dongle. However, there was no way to check or clear DTC's with it. Only with the cable was I able to see those options.
21VBRanger
Bo
Overland Park, KS
2024 Ranger XLT Supercrew
Travel Agent & Compliance Manager
I tried finding the turn signal from 3 to 5 but not able to locate it. Anyone know where it is?
Also wanting to turn off the seat belt buckled screen on the speedometer when someone buckles/unbuckles.
HyperM3
Lawrenceville, NJ
I saw that turn signal option in there when I was doing a deep dive. Ill have to go back and figure out where it was again. For the seatbelt screen, just use the codes mentioned above. It worked.
Phlfwd22
Matthew
Tampa
Firefighter
So this truck has an option in the settings under vehicle for “quiet start”.
Am I the only one that would like an option for a loud start?
Would be cool to be able to cold start the truck with the exhaust in “Baja”.
Maybe this is something that could be figured out in Forscan?
I often turn the truck on (hit the button without holding down brake pedal) and switch the exhaust the Baja, then start the truck up. It’s a pain but if you want that loud start..
