MPG loss with Cobb intercooler
Venice Raptor
Scott
Venice Florida
2024 Ford Range Raptor
I have the FP tune on my raptor. I just installed a Cobb intercooler and dropped almost 2 miles per gallon. (It went from 16 to 14). Does something need to be reset.. what am I missing? I assumed my mileage would get better from all that I've read on this forum.
Aircraft examiner
I wonder if thebair charge temp has dropped now so the ecu enriched the mixture a bit
Can you unhook the battery and see if it will start relearning? I am not sure if you can, just asking.
As far as firdt thing i mentioned, cooler air requires more fuel to be at stoichametric (not sure if i spelled that right) so it would use more fuel to stay at whatever the ecu is set to run at. A leaner setting is usually higher temp and a richer fuel mixture is usually cooler and doesnt preignite (knock)
Deepsea619
California
Tacoma
US Navy
I am stock with a blow off valve and I get 14.9. Maybe you have the same issue as I do, we drive like assholes.
Venice Raptor
Venice Raptor
Scott
Venice Florida
I just reset the truck by disconnecting the battery I'll see if that does the trick.
Mad_Motorhead
Chad
SC
It
It's likely the removal of the active grill shutters
Venice Raptor
Venice Raptor
Scott
Venice Florida
The Cobb intercooler did not require the front active shutters to be removed only the rear "floppy" ones Which were attached to the factory intercooler. The Cobb installation was quite simple actually.
T-Rev
Boost leak would be another potential cause.
