Mudflap hardware and hole template for 2025 XLT
Zachary
North Carolina
2025 Ranger XLT (2.3)
Parole Officer
Good Afternoon,
Recently bought the Rokblokz original universal mudflats for our 2025 XLT. Does anyone have a template that I can drill the holes for the front and rear? Also what hardware (bolt size) do these trucks take so I can mount them?
Thanks!
can you hold it up the inner fender and mark the holes from there using the fender plastic mounting clip holes as the template?
Zachary
North Carolina
Parole Officer
My goal this weekend is to take a piece of cardboard to get the mounting holes and then line it up on the mud flap, drill a pilot hole and then adjust before drilling the others. I should be able to make a template for others that have non raptor models.
From what I can see online it looks like the non raptor models use a push pin for the mud flaps? I’m guessing I’ll pick some up at the parts store incase I break a few.
they are those push in bases with the center plastic screw that spreads the legs so it doesn't come out easily. a two piece plastic twist lock screw
Ford Ranger Mudflap hardware and hole template for 2025 XLT 1774363511940-n
Bruce
Bruce
Minnesota
If you had negotiated with your dealer, you probably could have gotten Ford's Ranger mud flaps at a discount, and they come with replacement screw caps in case you have to drill out the factory ones. And you don't need a template to install.
And they say FORD on the flap.
Zachary
North Carolina
Parole Officer
Definitely wanted something like that. From what I was told the Ranger raptor flaps don’t fit a non Ranger, even Rokblokz has Ranger raptor models but not non Ranger ones. There’s many options out there but we pretty much have to overland to get to our cabin property and I wanted to keep some of the mud/rocks/sand off the cab and needed a rugged flap for it.
Zachary
North Carolina
Parole Officer
Installed front and rears. I screwed up the fronts so there an extra set of screw holes in the mud flaps but the holes are inside the fender. I initially measured but didn’t take into account the curve. Then I taped a large envelope to the fender and made a perfect template. Rears are perfect with no extra holes. Whenever they release the official ones I will buy a front set.
Ford Ranger Mudflap hardware and hole template for 2025 XLT IMG_8944
Ford Ranger Mudflap hardware and hole template for 2025 XLT IMG_8945
