Need wheel spec help. Im getting confused!
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
Please be gentle, Need wheel spec help. Im getting confused!
2024 Lariat FX4
looking at rims that are:
18x9 / 6x139.7 / offset +12 (G-FX TR19)
Im pretty sure this is the right specs, but website says "Doesnt fit your vehicle"
What am I missing?
Alaska Steve
Alaska
Factory specs:
Wheel: 7.5Jx18 ET55 offset: 53 - 57
Bolt Pattern (PCD): 6x139.7 (6x5.5)
Thread Size: M12 x 1.5
Tire: 255/65R18
Daweism
Austin, TX
2024 Lariat FX4
What am I missing?
Keep in mind many site will say a wheel will not fit if they are not exact factory specs.
Also mind the hub bore, there are not many hub-centric wheels for the Ranger and you will need a hub centric ring adapter which is really cheap.
RTR makes very light, strong and hub centric wheels for the Ranger at 22.5lbs.
https://www.rtrvehicles.com/collect...Yh9Os553glwXCqacnrkU9Wj066Ktar5CXzgRNF9HqbE6X
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
This adds a whole new layer to my confusion :(
This is the wheel I am looking at:
https://www.amazon.com/G-FX-TR19-Cu...+tr19&qid=1743090411&sprefix=,aps,172&sr=8-13
Amazon says it fits, 2 other wheel/tire sites said it did not. Lots cheaper at other sites.
IDK anything about hub centric or hub adapters, thats all new to me.
Im simply trying to get a psuedo affordable with a wider stance than stock, and all black.
Daweism
Austin, TX
I would stick to well known brands such as Method, RTR, KMC etc. Also check the weight of the wheel compared to your stock ones, you want to go lighter which helps accelerations, braking and fuel efficiency.
Also just incase you did not know, if you get a wheel thats larger in diameter, you will need new tires that fit the wheel. You can usually go up to 1/2 inch to 1 inch wider with the same diameter on the wheels and still use stock tires.
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
I got this whole thing figured out and got the exact look I was hoping for.
I will do a full write up with parts and pics in its own thread.
I ended up with a wheel with a Hub Bore 106.2 so used a 93.1mm ID to 106.1mm OD - Silver Aluminum Hubring and it all fit perfect. +12 on the new wheel offset
