New Downpipe Option? - CP-E QKspl
Locust13CT
Tom
CT
Aircraft Inspector
FYI, Looks like we have another Downpipe setup to choose from, theres 3 different options: EcoF($2295), High Flow($1595), and Track only($1295). LINKED
Not really sure what EcoF is and why it's a premium over "high flow"
Ford Ranger New Downpipe Option? - CP-E QKspl 1793435349515-f1
Ford Ranger Raptor Downpipe Features:
  • 3.00" Piping
  • Only one available with stainless steel, cast bellmouths!
  • Replaces unreliable factory downpipe
  • Fully mandrel bent and formed using state of the art technology
  • Step by step color directions
  • Titan finished
  • Available Lifetime Limited Warranty
PRODUCT DESCRIPTION:
The cp-e® downpipe set for the Ford Ranger Raptor is unlike any other. It's engineered from the ground up to be the most durable and robust downpipe available for this truck. Every design element was meticulously considered, including unique cast stainless bellmouths built to outlast the vehicle itself. These are crafted to be far more durable than a traditional flange and tube setup held together by welding. The design is tailored for an exact fit with the Ranger Raptor, with an upper O2 bung port cast into the structure for optimal placement, a crucial feature given the tight confines of the engine bay and exhaust tunnel.
Our catalytic converter is brazed to the outer shell's sidewall to ensure unrestricted airflow, avoiding the conventional stuffed and rolled method that can compromise durability. To enhance strength and improve exhaust flow, we also stamp the endcaps.
Further down the tube, you'll find a secondary O2 sensor, precision CNC-machined in-house to achieve an exact fit on the tubing, allowing for superior welding. This sensor is more accessible and doesn't require casting in place. We mount it with CNC laser-cut brackets produced in-house, setting it apart from those that merely use rods or flat sheet metal. This added attention to detail reflects our commitment to pushing boundaries.
The tubing itself is CNC-bent from 16-gauge stainless steel and formed as a single piece. Using thicker stainless steel than many competitors, we ensure the downpipe can withstand the high temperatures and vibrations typical of this part's location in the exhaust.
All fixturing and welding are done in-house, with each fixture designed on a computer and set using CAD to ensure consistency. This approach takes more time initially but results in a highly refined product.
Ford Ranger New Downpipe Option? - CP-E QKspl 1793435421440-n5
Ford Ranger New Downpipe Option? - CP-E QKspl 1793435435294-pz
Ford Ranger New Downpipe Option? - CP-E QKspl 1793435450413-z3
GEN3SKI
West
Ranger Raptor, Bronco Raptor
Work with procal? Appreciable gains on stock turbos?
25Dsand
Sioux falls
2025 ranger raptor
usps
man I want to do a downpipe but going to wait a bit for some reviews see what others think about it not trying to go to crazy already lol
landiscarrier
Landis
pocono mtns
sales
Save your money on this and just get GooseTuned. lol.
Locust13CT
Locust13CT
Tom
CT
Aircraft Inspector
I've been holding off on the SPD downpipe for a sale (Black friday?), But I might bite on this once i know the difference in downpipe options EcoF vs High flow. I'll reach out on monday. Also I'm assuming "track only" is catless?
Salty
Cyprus
Ranger raptor V6
What's the reason of the three holes at the top? Really looks like a quality product
Locust13CT
Locust13CT
Tom
CT
Aircraft Inspector
O2 sensor, an EGT sensor maybe? wide band sensor? I figure it's provisions for room to expand. Any not used would just get plugged.
Buellsox
Scott
Tacoma, WA
Local 26 Union Plumber
Quick lookup looks like the track only/off road option IS catless and the other 2 pricing options have to do with the quality & material of internals of the cats construction (read the cat conv. section). Plus these are higher quality 316 ss versus their standard 304 ss construction.
Ford Ranger New Downpipe Option? - CP-E QKspl IMG_1238
Locust13CT
Locust13CT
Tom
CT
Aircraft Inspector
No install for the ranger posted yet but this is from the Bronco Raptor install instructions showing unused ports:
Ford Ranger New Downpipe Option? - CP-E QKspl 1793528402391-am
