OE muffler swap to Magnaflow
Muffin1
Rob
NJ
I finally stopped procrastinating and decided to just get the muffler and not a complete cat back exhaust, i really couldn't justify the cost of a complete system (at this time) running from the $700's up to $1100-1200 depending on SS material and the other config options.
So i went with the Magnaflow #12577 (409SS) for $167 and a local muffler shop charged $150 to cutout the OE and weld in the new one.
I used this same muffler on my 5th gen '19 Ranger and was satisfied with the sound and better throttle response, although on those 5th Gen there was a resonator after the OE muffler right over the axle section, on the 6th there is no Res, Ford deleted it. so, i was concerned there might be drone.
I was able to get it on a highway going out to a family get together today along with local street driving, and yes there is a noticeable tone but i wouldn't call it drone, the highway had a hill that has a 6% grade and at 72 with CC set i was hard pressed to hear any annoying sound. (radio off)
It's a good budget option if you don't want to spend $$ on a complete system.
When i do a longer highway trip, I'll update any observations.
fordc51
Jim
Cumming, Ga
93 f150, 2025 ranger xl
Raptor r ranger. If ranger is it 2.3 ? If/when you think about it record and post sound with new muffler. Thanks
Muffin1
Muffin1
Rob
NJ
It is a XLT 2.3, will try getting a audio clip.
fordc51
Jim
Cumming, Ga
25 2.3 XL here
Stock dont sound bad for a 4 cyl compared to some other 4 cyl trucks. 2.7 sounds better.
My muffler shop did a generic muffler that was single in/dual out and ran duals out the back for a little more. If you get bored and want to change up the look, try it next time and it may help with noise too. Mine is very quiet but when I am not in the truck and I remote start it, you can definitely hear it way more then when it was stock.
But good deal on the info for everyone. Since mine is generic, I cannot out a part number up to help out for people
Muffin1
Muffin1
Rob
NJ
I have two vid clips but am not able to dwnld them to this post, i get the 'oops something went wrong' message, in guessing there to big 55 seconds and similar for the second.
The cold start db's were roughly 82-84 and rev dbs got to 92-94, idle at 74.
Anybody know what the max size of a vid attachment is i can give it another try?
Its surprisingly not loud at all for the straight thru design that it is, which I'm actually happy about.
Wasn't looking for loud, wanted a more free flow efficient design and that's what i got for a total OOP $327. :)
Muffin1
Muffin1
Rob
NJ
Thanks for that tip.
And on the cold startup vid you can hear the fans kick in right after startup they're noisy, lol.
Muffin1
Muffin1
Rob
NJ
After a couple weeks and a few hundred miles highway & local there's no issue with drone, sounds great when i push the pedal and the throttle response is much improved, it really pulls like when getting on the highway and up to speed it's very quick and seems effortless.
As for mpg's generally the same except a little better when easy on the pedal and keeping it around 70 when on the highway i calculated a 0.6 tenths mpg better (22.6 VS 23.2).
My goals were met, inexpensive setup that sounded better, and removed the restrictive muffler for better engine efficiency & throttle. So satisfied overall.
Hopefully this helps anyone interested in a similarly budget friendly exhaust mod.
fordc51
Jim
Cumming, Ga
Is your truck a v6 or a 4 cyl,? How expensive are the mufflers n instsllation?. My truck is a 4 cyl, im guessing yours is a 6 cyl?
