RichD
Rich
Washington state
We got 5” of snow last night. Western Washington has the wet, heavy, cement like snow so I was interested to see how the OEM Wranglers that come with the FX4 package would do.
They did fine-ish. Seemed like the Toyo Open Country 2’s I had on my Jeep were a little better overall.
Checked out the “slippery” setting in 4h too. Seemed to work well. Braking-ABS also functioned as it should. Musology mud flaps also worked well.
So far, so good.
Ford Ranger OEM Goodyear Wrangler Tires performance - first time in the snow IMG_7649
Ford Ranger OEM Goodyear Wrangler Tires performance - first time in the snow IMG_7650
Ford Ranger OEM Goodyear Wrangler Tires performance - first time in the snow IMG_7658
Fix4Dirt
SLO County, CA
The goodyear tread looks to me like wheelbarrow tire hahaha. But all jokes aside about it, glad it works well!!
Brent H
Brent
Alberta
2024 Ranger
oil and gas
I'm in Edmonton Canada lots of snow and Ice for 5 months, simple trick is to reduce air pressure in your Wranglers from 44 psi to 30 psi better ride and more traction in snow and Ice.
My air pressure is rated at 30 psi for the Lariat FX4 are the others that high at 44psi.
Massman
Ed
MA
2024 Ranger Lariat
This is good to know because my 04 Explorer Sport Trac came with Goodyear Wranglers and they were terrible in the snow. In the first snow storm with the Sport Trac 4x4, I almost got stuck on the way home from work. I live on a rather steep hill, but l I managed to get up it in my 74 Fire Bird and my 85 T-bird (with a running start), so I expected no problem with a 4x4. Couple of days later I bought a set of Michelin M&S all seasons and never had an issue in the snow. Picked up a second set of wheels and used the Wranglers for summer weather.
Bonder
Manitoba
I rate my Lariat FX4 Wranglers as low/poor in snow and ice. In 4x4 they are fine, but in 2wd it is much easier to break the back end loose then it was on my last gen Ranger Lariat.
Once you know how easy it is to break loose, adapting your driving is enough to overcome it, but I expected more, since the Duratracs I had on my old F150 were great in the snow/ice, but they were snow peak rated as well.
I too am running them at door pressure, not >40, that seems like crazy talk. :)
RichD
RichD
Rich
Washington state
If I’m driving on snow or ice, which is rare here, I’m in 4H. Luckily for us, the roads get plowed and it usually warms up in a few days. Maybe 3-4 times a year it gets that way. And yeah, no need to lower psi if I’m just careful.
RangerRider
Patrick
Watertown, SD
2024 Ranger Lariat 4 x 4 (Hot Pepper Red)
One of the things I learned when I had my 1998 2WD F150 driving in Colorado to improve traction for the back wheels was to put 5 or 6 50lb bags of sand in the bed over the rear axle.
So now during the winter months here in SD when there is heavy snow I do the same with my 2024 Lariat with the OEM Wrangler tires.
Even in 2HD the traction is significantly better.
VehicleNanny
Bill
vehiclenanny.com
Retired from General Motors
Which trim recommends 44 psi? My XLT (non FX4) recommends 38 psi front and rear. Unloaded, that feels high to me. I'll run 32 psi for the right balance of ride and handling.
RichD
RichD
Rich
Washington state
Definitely would do that if we had long term icy conditions. Sandbags over each tire in the bed usually do the trick
TractorFixer
Iowa
So far, so good.
I agree with your assessment. Have the same Goodyear tires on my FX4 and snow performance has exceeded my expectations. Not as good as a 3-peak rated AT or snow tire, but does decent for what it is. Certainly better than the Goodyear tires that came in my F150, which were worthless on anything but dry pavement.
Truckin
24 Ranger
Just for a reference I went from oem goodyear to Falcon ATW4s and falcons were worse wet and cold. Miss the look and went with Michelin defender and they are better all around. Went through 4” snow in 2wd and next morning plowed but slush and ice and still awesome
RichD
RichD
Rich
Washington state
It's tough to beat any Michelin tire in all around street performance.
RangerRider
Patrick
Watertown, SD
Agreed.
Michelin Defender LTX M/S 2 was all I ran on my 1998 F150 & 2004 Explorer when living in Colorado.
The Ranger will get the same treatment when the oem Goodyears wear out.
mrmike7189
MA
2024 ranger STX 4x4
My XL/STX Ranger also recommends 38PSI.
Ford Ranger OEM Goodyear Wrangler Tires performance - first time in the snow 20250530_110904
