OEM subwoofer size / spec
RRaptor24
Bubba
Prius
Crane Operator 😜
Did you replace the sub? Has anyone tried upgrading the speaker?
I did. I added an amp and a sub under the rear seat. Bought a plug and play harness. Sounds amazing
I have all the links if you’d like them.
Reactions: DMC
RRaptor24
Bubba
Prius
Crane Operator 😜
Please do on the links, thx
This is the sub enclosure
https://www.ebay.com/itm/1926103196...-aneEvjQ1K&var=&widget_ver=artemis&media=COPY
this is the sub I got and it fits and sounds fantastic
https://volunteeraudio.com/product/hertz-mps-250-s2
This is the plug and play adapter, no cutting into wires and comes tuned and set with the kicker keyloc. I picked the option to get rid of the factory bass roll off.
https://soundsgoodstereo.com/produc...-o-including-unleashed-read-description-below
As for the amp, you can pick any brand you want, if you’re only adding the sub you will need a mono amp with a RMS of 600 watts. The kicker amp I used has is a 800w amp which pushes this sub perfectly. But I’ll attach the link to the amp I used, I like this amp because it has a Bluetooth bass knob so you don’t have to run a remote wire.
I had it installed at a custom stereo shop, they were ranting about the ease of the install with that harness and the quality and sound of the system
https://a.co/d/aWzJ4E1
any other questions just ask
Snkrjeff020
Boulder, Colorado
Medical Scientist
The Kicker LOC you ordered is for the round BO system?
RRaptor24
Bubba
Prius
Crane Operator 😜
Yes sir! It may not show for the 2024 model but the one for the 2023 is what I ordered.
Snkrjeff020
Boulder, Colorado
Medical Scientist
Okay cool, I almost ordered the first one that was Bo unleashed for oval. Glad I checked with you first.
Is it the US Rangers that had round sub, and AUS had oval?
RRaptor24
Bubba
Prius
Crane Operator 😜
Apparently they put the oval in the Aus trucks.
jorosz0309
Minneapolis
Do you happen to know the volume of the sub box? I was looking online to try to find that info to match a sub, but couldn't find anything...
Catalyst
Justin
Bend, OR USA
Network Engineer
I inquired with the seller of these enclosures, and this is what they said:
"Hey mate needs to be a shallow 10" as there is only 10.5liters volume. Also be careful what sub as the outer rim of the sub cannot be larger than 272mm."
So .37 cubic feet and 10.7" max outer diameter of mounting flange.
jorosz0309
Minneapolis
pretty small. I’ll be curious to see which subs get used. I’m thinking the Kicker CompRT would work well at a good value. Otherwise spending twice as much to get the JL TW3 or Hertz MPS 250 (like RRaptor24 did here). The Rockford Fosgate options out there look to want more volume.
Catalyst
Justin
Bend, OR USA
Network Engineer
I also was looking at the Focal shallow 10" sub as well (standard or flax) - both take min. .35 cubic feet sealed. I'm leaning towards the TW3 for dual voice coil.
RRaptor24
Bubba
Prius
Crane Operator 😜
I’m not sure the volume, but I will say that my Hertz Mill Pro 250 sounds amazing
