Oil drain plug
roadpig58
Dominick
ocala Florida
2026 ford ranger xlt 2.7
New here- just bought a 2026 XlT with the 2.7- having trouble with oil plug replacement. What is the correct part number that came on my truck? Ford oem parts sites confusing?
thanks​
Chuck2001
Montreal, Canada
25 RR, 24 Golf R
My answer will probably be useless to your question, sorry in advance :
None, suck the oil from the top and never touch the plug.
You could call your dealership service dept, they could check it out for you.
roadpig58
Dominick
ocala Florida
Thanks- went to the dealer and picked up a couple of plugs -they’re the newer design with two orings-
wyjim
Will
Northern Nevada
2025 Ranger XLT 2.7 /4WD /Sport /Desert Tan
I believe this is the newer plug.
Ford Genuine Parts Oil Pan Drain Plugs ML3Z-6730-B
Ford Ranger Oil drain plug IMG_0039
roadpig58
Dominick
ocala Florida
Yes that’s the one they gave me just wondering if that’s what I’ll be taking out s
josephp732
Joe
NJ & FL
I'd think about replacing the factory with one of the UPR plug or Ronin plug. Never get hit with the Niagra Falls of oil again. I have the UPR ball valve version and can easily manage the flow of oil directly into my 5 gallon recycle oil jug without attaching a hose - I don't even have to use an oil drain pan.
https://www.uprproducts.com/product...-for-mustang-f150-raptor-edge-explorer-bronco
https://www.uprproducts.com/product...98065&pr_ref_pid=8231440613553&pr_seq=uniform
https://www.amazon.com/dp/B07H56TP4F?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
https://www.amazon.com/dp/B0064O8OYK?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
