Oil Pressure Gauge on XLT
Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
I have a 10" screen. Is there an oil pressure gauge. I can get oil temp.
RRXLT
Roy
Waelder, Texas
2000XLT 2025XLT
I would think so. On my 8” cluster you scroll down to “off road” then down to “gauges”.
It does, under engine gauges somewhere in the My View settings.
I have gauges showing, boost, oil pressure, trans temp, but they are just bar graphs, no read outs.
Scooter
Scooter
--Machinist
I will look at Off Road. I have looked under Gauge view. Just can find oil temp there.
I had a tire puncture. Through motorcycling I have some good Button Plugs. The button expands inside the tire. Works Well. The Tire pressure screen is very helpful.
Scooter
Scooter
--Machinist
I found the location. Yes just vertical bars for gauges. Will have to look at what those are measured in.
The first one, shows Turbo Boost. Will have to accelerate hard to see if i get boost.
Middle Oil pressure runs about 1/4 of vertical bar. Goes up a bit when accelerating. Would have been good to have a high pressure oil pump,
Tranny temp, seems normal and rises as you drive the vehicle. Things warm up.
Get's to operating Temperatures.
I looked through the manual. What should these gauges read at.
Another ? would my XLT have Hill Descent.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
if your set to metric, they are measured in BAR, says right under it. you have to set to imperial to get PSI. its stupid, we can mix metric and imperial on things. like I want psi for my tires, and can switch it from kpa/bar to psi.. but I cant with the extra engine guages in the off road screen. lol
Ford Ranger Oil Pressure Gauge on XLT 20260306_204523
Scooter
Scooter
--Machinist
Thanks @ShadowDragon24
Where's the conversion. Would like to see MPG.
Yes, PSI for oil pressure would be more helpful.
NM Mike
In your center console settings, you can select between metric or imperial units.
