Please help! Question regarding tonneau cover and drain holes.
Elgin_Ranger
Los Angeles
2024 Ford Ranger Lariat
Thinking of getting a retractable tonneau cover that requires holes in my bed to drain the water out. Question, I don't see any holes, it's already blocked by the bedliner, but I do see bigger holes on the side of the bed, can I use that hold as a drain hole? Thanks. Picture included.
Ford Ranger Please help! Question regarding tonneau cover and drain holes. Bed
SubaruRaptor
Jory
North
That hole is used to mount things like the adjustable cargo rails. The drain holes would be at the bottom of the picture (in that oval). You can use them as drains though, should work just fine. If they didnt then that cavity would fill with water naturally.
Rda2w
Robert
Upstate NY
That is where I ran my drain tubes. The Undercover tubes fit the hole perfectly.
fordtrks4ever
Perkiomenville, Pa
That is where I ran my drain tubes also
patc890
Patrick
Rockville, MD
Ford Ranger Please help! Question regarding tonneau cover and drain holes. IMG_0304
Ford Ranger Please help! Question regarding tonneau cover and drain holes. IMG_0272
I didn’t notice those holes when installing mine. This is what I did, seems to work fine.
fordtrks4ever
Perkiomenville, Pa
Nice. So you used the same hole as I circled? Would you mind sharing some pictures?
No I ran mine in the same side hole as Rda2w
I did not want anything in the bed to interfere with the drain hoses.
