Professional ceramic coat... what brand(s) do you recommend?
I've got a bunch of detailing shops locally that install ceramic coatings and each one seems to use a different brand, none of which I've heard of. Most of the shops have good reviews as well, so that doesn't help me narrow things down either. It's honestly a bit overwhelming, and I'm already starting to get analysis paralysis.
What I'd like to know is what brands do you like, what brands to avoid, and general advice on what actually needs coating and doesn't, i.e. don't get the wheels but do get the windshield, or two coats isn't worth the cost if you plan to reapply at home annually.
Thanks in advance for helping me sort this out. Cheers.
SubaruRaptor
Jory
North
What brands do they use? To be fair, almost all ceramic coatings will do the same thing. Think of it like this. When you get pasta, you have to pick a noodle. All noodles are made the same, just cut differently and have ever so slightly different textures or shapes. This is very much the car detailing world and ceramic coatings in general.
AMGRAPTOR
FL
2024 Raptor Ranger
Gtechniq crystal serum light or ultra. Topped with exo v5 I have personally applied this coating myself on multiple vehicles. it’s my go to.
I don't know if I can agree with that. My experience with detailing products is that some are really good, some bad, but most are simply marketing hype on top of so-so product. The latter two are my biggest concerns. This isn't going on a garage queen. It sits outside year round, so I want to get the best coating possible.
SubaruRaptor
Jory
North
any of the big names will do you fine. What brands are being offered.
Xpel, Opti-coat, Undrdog, System-X, Ceramic Pro,, HydroSilex LIT... each place has a different brand it seems, and there are a ton of places in Memphis. That was just from the first 6 links of local shops I opened in Google.
SubaruRaptor
Jory
North
Xpel and Ceramic Pro are going to be the big boys. Ceramic pro has a lot of haters for various reasons.
I can only speak for XPEL Fusion Plus. It looks amazing on my Lariat. Compliments of the dealership for swirling up the clear coat during PDI.
SubaruRaptor
Jory
North
Haters? Why?
Some folks say it is overly hard aka cant be removed, some say its too soft, aka it can be removed to easily. Some think it can ruin the paint, theres just a lot out there. For every horror story there is plenty of "i have used it for ever" stories.
If you read between the lines a bit, most folks dont realize you need to maintain ceramic coatings (yearly top up) and that they can become blocked up. Hitting a ceramic coating with an acid will unblock it and itll start behaving like new again.
Stitsch1618
Peter
Zurich Switzerland
Ranger Raptor New Gen
My 2 cents: I had a full ceramic coat on my F150 Raptor but it did not protect of severe Trail Rash and needed some severe care after every offroad adventure.
I did a full coating transparent wrap on my Ranger and have no trail rash or does it need any polishing etc. - just a short hose down or strong rain the truck looks all shiny again.
I also added a second sticker layer on top of the clear wrap. in the sun it looks cool too.
Ford Ranger Professional ceramic coat... what brand(s) do you recommend? 20240319_152420
Acid wash?
Maybe I need to be schooled on how this works. I thought the point of a ceramic coating was to put a hardened, hydrophobic coat over the paint to protect it from environmental contamination, e.g. bird and tree droppings, and make the surface easier to wash off with a hose end sprayer with or without soap. Also, that these coatings simply need to be touched up at home about once a year with an off the shelf product like Adam's or Chemical Guys to help maximize its longevity. Basically, the modern equivalent of a once a year wax. You get it done professionally, protect that with a yearly home application, and simply hose it off between washings?
How far off from that am I?
So your take is that PPF would be better for our application than ceramic? I thought PPF can scratch and etch pretty easily?
SubaruRaptor
Jory
North
Acid wash?
Acid wash?
Not to far. Most "professional" coatings have built in maintenance plans with the installer. That should be explained and such when purchased so you can get the rated longevity they advertise. That maintenance plan is usually an inspection of the existing coating and reapplication in areas if needed or unclogging it.
Most professional coatings are very long lived and unless you do a strip wash or some aggressive washing, you arent going to wear it down. People sometimes attribute the coating not beading water correctly as it is gone when in a lot of cases it is "clogged". Over time the coating surface will simply develop a film of stuff that normal washing cant remove be it dirt or other products, hence the acid wash. The acid wash will remove the film on the top of the coating and re-establish the hydrophobicity of it.
You as the consumer only need to worry about applying to many layers of protection by using competing products as they wont stick right, or react right, etc. Generally speaking the ceramic coating prevents lots of things from sticking to the car and makes washing easier. Cleaning the coating (washing the car) and applying a topper should be all you need. Just make sure your topper is compatible with ceramic coatings and that it isnt doing something your coating already does. Whats the point of adding a topper that beads water when thats what the coating does for example.
