Project Msfitoy V3.0
Msfitoy
Msfitoy
Sid
North Carolina
2003 MINI Cooper S Modified
Big Toy Designer
Can you share more info on how you wired up the Trigger? A relay for vehicle power would be good for this I think, but I'm curious what you did about this.
Sure...it's simple...three wire coming out of the unit...red, black, yellow...red goes to positive battery terminal, black goes to negative and yellow is optional...if you aren't afraid of random RF turning on your lights, then connect this to red for always powered...if you like to have the unit armed only when another circuit is on like in my case the marker lights, then connect the yellow to the hot lead of the marker lamp...for that info, please dig back through my project for the wiring process of the DIY Raptor lights:)
Gizmokid2005
Long Beach, CA
gizmokid2005.com
2019 Ford Ranger XLT 4X4 SCrew
Data Analyst
Thanks! I'm not going with the Trigger, it's just too rich for my blood and I don't need all the fancy tech you have! :crackup:
I just picked up a simple fused distribution box I'm going to wire in. I may have to do a bit of digging, but the marker lights would be a good one.
Msfitoy
Msfitoy
Sid
North Carolina
Big Toy Designer
You just wanted to me type a lot eho_O:LOL:
El Renno
Mark
Jefferson City, MO
2019 Ford Ranger
The LEDs were wired together in parallel and the positive tied into the top left lead (yellow/green) which are switched on/off with the marker lights. The negative tied to any ground bolt under the hood.
Well, using the same lights as you (white instead of amber, though), I used Stage 3 Motorsports wiring harness to plug into the marker light. But the lights would never light up. Volt meter said there was 12v there, but still nothing. So, being as I'm not electrically inclined, I'm going to have a local shop find an alternative wiring setup like yours.
One question about this photo: where is this yellow/green wire located? I can't figure out that location.
Msfitoy
Msfitoy
Sid
North Carolina
Big Toy Designer
I'd follow Stage 3's instructions...their set up probably is different...the yellow/green is upper left looking down...or is it yellow/orange...you'd have read back in my build as someone corrected me...:)
Cdveltri
Denver
2019 Ranger XLT
Another step closer...got my "Last Line of Defense" style Front Runner racks mounted to the Diamondback...without the RTT loaded, both hatch open normally:)
Looks great! How many fasteners are used to attach each of those tracks to the diamond back and what size are they?
Msfitoy
Msfitoy
Sid
North Carolina
Big Toy Designer
The tracks came in a set of two 1400mm...each need to be cut into two so the hatch can still open...that left two fasteners for each half but I added an additional fastener...not sure about the size but I can check if you need them...
Cdveltri
Denver
2019 Ranger XLT
No need to go out of your way to check. I also took inspiration from LLOD, but I wanted something a little more low profile. I ended up making my own system out of 8020 extruded aluminum. I did a similar split track and chose to use 3 fasteners per track. I was mostly curious if that was in line with front runner solution. Thanks for the help!
Msfitoy
Msfitoy
Sid
North Carolina
Big Toy Designer
Yes, I ended up adding another fastener for 3 on each rail though it didn't seem to need it as the originator of this setup, "Last Line of Defense" didn't and he's had many different tents up there doing a lot of off roading:like:
Msfitoy
Msfitoy
Sid
North Carolina
Big Toy Designer
Don't know why I waited so long! Finally got into Forscan mods:)
Got the following done:
1-calibrated 33" tires for speedo
2-ding ding chime killed
3-Bambi light...YES!
4-Dark mode
5-Seat belt chime
6-killed auto start/stop:like:
A few thoughts on this...first the recalibration worked just about perfect...before, at indicated 66mph, my actual GPS speed is 70mph...after calibration, indicated speed 71mph is 70mph GPS...same one mile per hour difference at 81 = 80...good to go:like:
Second, my city mileage before was 18mpg +-...after 22mpg+-...interesting! I always figured that I haven't actually traveled the indicated 28,000+ miles as I have larger than stock tires...also the mileage calculation is the same 4mph difference in speed before and after...so like I had theorized, my actual MPG is brighter than before:like:
Third, the dark mode seemed to work as described EXCEPT when in full auto mode it doesn't allow fog!o_O So I turned that off as I really didn't see a need in my case...
Next up, turn off the door open chime:wink:
El Renno
Mark
Jefferson City, MO
2019 Ford Ranger
It looks like the polarity was reversed. Everything else checked out. Finally got mine working. Thanks for all your help.
Ford Ranger Project Msfitoy V3.0 IMG_0593
Msfitoy
Msfitoy
Sid
North Carolina
Big Toy Designer
Specs to date:
Drive train:
1-AFE intake charge tubes
2-K&N filter
3-MBRP 3" cat back exhaust, black
Exterior:
1-285/70-17 Falken ATS-W
2-Fuel Shok Anthracite, 17x9 +20offset, custom hub
3-Eibach Pro Truck four strut kit
4-Custom flat black graphics
5-LED fog light modification
6-Rigid LED, 2 spot + 2 flood in grill
7-Rigid LED spot hood mount
8-Baja S1 Ditch light hood mount
8-Pro Comp LED flood rear bumper mounted trail lights
9-Raptor grill, custom amber LED x 3, Magnetic FORD overlay
10-Center custom rear marker red LED x 3
11-Diamondback SE armor bed cover
12-Bushwacker Tail Armor
13-Front Runner rack mount on top of Diamondback
14-Shrock Rock sliders
15-Four side flood camp LED mounted to Front Runner load bars
16-Lumen Tech 8 LED under body rock lights
17-Cab spoiler
18-Tailgate flat black FORD inlay
19-Custom FX4 Overland flat black graphics
20-CB antenna centered on ditch light bracket
21-Shortwave antenna
Interior:
1-Ram mount Ipod Mini
2-Ram mount Iphone
3-Uniden CB
4-Balfeng GMRS/SW radio
5-Trigger 3001 RF six shooter accessory control
Up coming additions:
1-Front Runner RTT
spicydaddy
Joseph
Pembroke, GA
2019 Ranger XLT
Breakbulk and RO/RO port management
4-Dark mode
5-Seat belt chime
How would one go about getting into Forscsan mods?
Msfitoy
Msfitoy
Sid
North Carolina
Big Toy Designer
