Ranger 2024-2025 Bed Mat for 5.0 Bed Installed
Catalyst
Justin
Bend, OR USA
Network Engineer
3 Putt
Nebraska
2024 Ford Ranger XLT
Within the last month, I purchased a 2024 Ranger. I’ve put on a Truxedo cover. It helps, but it definitely does not keep all the water out. Not bad though. All that said, I’ve been looking at possibly adding this Ford mat to the bed. I dont have a spray in liner. Im a bit worried about moisture getting under the mat and causing rust. I’ve never put a mat in before, but like the idea of reducing cargo shifting. Can you let me know your experiences with mats and rust? With a tonneau cover, it doesn’t seem like it should be a big issue, but just curious. How often should you take it out and clean/air things out? Thanks.
Everyone always says rust but i have owned many trucks (with those plastic bed liners thay are supposed to be worse then anything) and i live a half mile from the ocean and i have had the paint rubbed off all the 2ay around the bed liner at the rails but never under any liner or mat so i dont see how you would get rust under this eith a tonneau cover
The last truck i took a liner off was an 01 frontier. It came from virginia and had been here in corpus christi for 5 years when i bought it, back in 2018. I took that liner off and the bed was spotless wxcept the edges where the rails hung over and rubbed it down to the metal. No rust, just down to the metal because the liner would shift each time you drove and sand the rust off, i geuss.
Awirez
SC
Pics attached. BTW, grabbed my calipers … it’s 0.27” thick.
0.27" - that's a far cry from 0.75" thickness, as advertised. Presumably the caliper measurement was from one of the raised lips on the edge and not including a cleat, right? Even if it did not include a cleat, there's no way the cleat is ~0.48".
Ford Ranger Ranger 2024-2025 Bed Mat for 5.0 Bed Installed 1742384789467-05
Salt_H2O
Salt_H2O
Northern VA
Agree, took the measurement on the edge, at the thickest part of the mat, not within the "indented" ribs. Quality appears super solid, the mat weighs a ton.
BlancoRaptor
Warren
Arizona
Just got mine
Good value with 15% discount.
Very heavy
Salt_H2O
Salt_H2O
Northern VA
On the front page of Ford Accessories site they list a monthly discount code. I think I bought my mat this month (March), so the code I used is probably still active. 15% off.
alrashid2
PA
I decided to drop in the Ranger OEM Bed Mat over my spray in liner. The spray in liner does its job so well, it sometimes scratches other items thrown in the bed.
Here are some picture of the new bed mat.
Sweet! I'm planning on using the Ford Points I get from buying my Ranger to pay for most if not all of this mat.
Did you find it to fit well? Doesn't slide around? Tight fit? And how thick is it?
Texasota
Al
Rochester, MN
About 3/8" thick. Fits very well and does not move around at all. I used one on my 2020 Ranger for six years and was happy with it.
alrashid2
PA
Thanks for replying!
I'm going back and forth on getting a bed mat. I think it'd be perfect for when I want a clean bed for road trips, where I'd be putting backpacks, suit cases, and such in the back. But when not doing that, I'll be using it to haul firewood, mulch, gravel, and lumber. I think I'd want to remove the bed mat as I'll have a spray in bed liner, but this thing looks almost too heavy duty for me!
I was actually hoping for a thinner mat, similar to a rubber interior floor mat - something just to protect luggage from being scratched up but can also be easily rolled up and stored.
alrashid2
PA
Hey brother, just curious to see how this bed mat is holding up!
One thing I noticed about this Ford OEM mat is that it is mostly flat on top, despite the bed having bumps. Aftermarket bed mats seem to follow the bumps of the bed - check out this pic below.
Ford Ranger Ranger 2024-2025 Bed Mat for 5.0 Bed Installed 1782481821691-82
I think I prefer the flatness of the Ford bed mat, but I noticed in your picture where you lifted it and showed the underside that the underside of the mat is also flat? Makes me think that this mat will get lumpy over time, or it'll have lots of air gaps under it that will squish when stepping on it or putting something on the mat.
Did you find that to be the case with yours? Makes me think an aftermarket mat would be better as it follows the contours of the bed.
