Replace 2025 bed rail caps with 2026 caps?
MikeVB
Georgia
2024 Ford F-150 work truck. Personal trucks: 2025 Ford Ranger XLT, 2002 F-150
Will 26 bed and tailgate caps fit as a direct replacement on a 2025?
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Just an educated guess but I think they would be backwards compatible, it's doubtful the bed body has been changed
MikeVB
Georgia
I had the same thought, but was hoping someone else around here had already tried and succeeded/failed before me, lol.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I actually had considered looking into billet aluminum caps(though the cost for custom caps would be huge)as the stock pre26 caps just crush down too much and they don't allow thru access to the many 8mm welded nuts under the rails. I've had the stock caps on and off a couple times and it doesn't do the many clips any good to be pulled or pushed, each one needs to be re-formed after and it's hard not to half break at least one or have one snap off. I do wish there was an aftermarket option available for the 24-26+ with at least solid material.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Looking around I'm not able to find the 26my redesigned caps part number, they look to be in the $170 each range for 24-25. Take a look at this item page stating the part can't be re-used/reinstalled...lol! Certainly it will never be the same after but it's definitely possible to do it and not be able to tell it was reinstalled just looking at it from the outside, at least one or twice if very careful
Ford Ranger Replace 2025 bed rail caps with 2026 caps? Screenshot_20260630-112330
Ford Ranger Replace 2025 bed rail caps with 2026 caps? Screenshot_20260630-112317
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
No idea if they are backwards compatible, but if they are keep in mind you'll also need a new tailgate top which is probably even more than the side rails.
MikeVB
Georgia
Yep, mentioned the tailgate cap in my OP.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
An offering made out of aluminum with countersunk clearance/thru holes for the 8mm under rail nuts would be awesome, bolt on/off with no clips and nice solid mounting surface. If they could be e laser cut with edge contouring/finishing it could actually be done at maybe close to the cost of OEM at $350-500. If they were fully CNC'd from billet that might be double that at ~$1k? Not too sure but seems in the ballpark and would be so cool to see that designed
Wolfman00
matt
crofton md
2024 xlt
so alu cab makes one. it’s part of the fitment kit for their caps. all it is- aluminum with the bed profile on top with a 90 degree lip on the inside.
MikeVB
Georgia
Got a link?
Wolfman00
matt
crofton md
2024 xlt
Got a link?
no, it’s on a pdf i saw, you can’t buy them. they come with the cap/camper. that’s what makes it a pain. no actual close ups of them.
i got locked out fusion, but i’m going to see if i can come up with something.
other idea- take existing bed caps off- fill the voids with epoxy to make it solid when you need it
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I did consider a liquid filler but the stake openings make it more difficult to accurately fill with liquid material and not run out of the openings
ScoMay23
East Tennessee
2025 4Runner TRD PRO (Mudbath), 2026 Ranger Raptor (Carbonized Gray)
