Retractable Bed Step recommendations?
gcextreme
Glenn
Starbuck, Mn
2025 Ranger
Service
I decided to add a retractable bed step using a modified Tacoma step, which was the cheapest ($117cdn)on Amazon. Made a bracket using 3”x5” x 1/4” x 6” long angle iron. Only drilled one hole in the hitch bracket frame. There is an oval through hole where a electrical connector clips in on the outer side of frame. Relocated it and the hole is available through to the inside face of the frame. Had to drill a 3/8” hole closest to the bumper on the outer side. Before all this metal work, I did cardboard and plywood mock-ups to test fit everything.
Do u have any measurements for the bracket and the hole locations?
Bagman51
Bagman51
Bob
Ontario, Canada
2024 Ranger XLT Sport
Mechanic, retired
Sorry, it was designed using cardboard templates and existing frame holes. Blow up the photos for reference. A lot of trial and error fitting.
alrashid2
PA
Thanks for your writeup. I'm tempted to try it too but my metal working skills are almost zero. I took wood shop in school haha.
I am utterly shocked that not a single aftermarket company makes one for our Rangers?
dfritz
Doug
Western Colorado
I used the ideas from this thread with a Tacoma step, the one I got from Amazon had a weird angle, and took a lot of fab mods to get it done. A super big problem is the factory towing set up, which is why it's hard to find a aftermarket step. This is the bracket I had to make, installation took some special tools and a step drill.
Ford Ranger Retractable Bed Step recommendations? 1778864306101-yt
Ford Ranger Retractable Bed Step recommendations? 1778864432404-eq
Bagman51
Bagman51
Bob
Ontario, Canada
Mechanic, retired
Wow, good job! A lot more complicated than mine was. Whatever works is the diy code!
